Using and removing temporary drive (Quick answer requested)
  1. Can I connect a portable USB harddrive to my Roon Core PC and have Roon add the files to my library?
    I know the answer to this is “yes.”
  2. Can I remove that drive, disable it in Roon and have Roon completely remove the files from its library listings?
Hi @mitr,
Yes, you can connect a drive and add it as a watched folder which will import the files.
Yes, if you’re wanting to completely wipe all memory of the files you can go to *Settings | Library | Clean Up Library`. Note that you only do this if you’re 100% sure you want all files that aren’t associated with a storage location to be deleted permanently. You may want to make a backup before if you’re not sure.
Thanks. That’s what I needed to know.
