TLDR: Would REW work not just for slight room correction, but to measure the room to account for speakers that require an EQ with +/- 20dB adjustments?
Longer version: As mentioned in the setup thread - I’ve got Bose 901 Series IV speakers (and I’m not likely to upgrade any time soon). The speakers come with an active EQ (currently between my pre- and power-amp), and it’s by far the weakest link in the system (I’ve had it rebuilt twice, and it’s on the way out again). As you can see here (scroll down 1/3 of the way), it does some pretty aggressive EQ.
After not really paying attention to HiFi for ~15 years, I came back to discover that DSP is a thing, and it works. My right wall is shorter than my left, so the soundstage has always been off-centre. I tweaked the speaker DSP settings in Roon and got it perfectly centred. Amazing! I then read Magnus’s excellent post about using REW to build room correction curves for a convolution EQ and got to wondering if it’s possible to replace the 901’s EQ (either in Roon, or with a MiniDSP).
It turns out Deer Creek actually sells a MiniDSP unit with the 901 curves. However I’d like to also do room correction.
So one option is to install the MiniDSP, then use REW to do room correction and add it to Roon (meaning no room correction for vinyl).
A second is to use REW to get the room correction curves and then either load it on to the 901 EQ’d MiniDSP (unsure if I can do this - have emailed them to ask), or add another MiniDSP with the room curves.
The third option is to pull the current EQ out, and use REW to do room correction, which I’m hoping might also build the 901 EQ curves at the same time. I’m wondering if that’s actually likely? Does REW work at such extremes (+/- 20dB) - or is it more just for small adjustments? I figure I can test in Roon, and if it’s working well, load in to a MiniDSP and get EQ+Room correction for my vinyl as well.
So am I dreaming, or is the third option possible? Are there any other options I’m missing (and yes, I realise replacing the 901’s is the obvious one!)
