In the past, Jussi has recommended the RME ADI-2 Pro FS R ADC/DAC Converter as a way to listen to vinyl in real time through HQP. The RME ADI-2 Pro FS has a lot more capabilities than what I need (for example, it has a DAC and I already own a separate DAC). Therefore, I have been looking at alternatives that allow me to keep using the equipment that I already have.
I just read about the RME Babyface Pro Audio Interface. This device has an ADC but no DAC which is just fine with me.
Questions:
- Can the RME Babyface Pro Audio Interface be used to listen to vinyl in real time through HQP as well?
- Since this device also has an optical input, could I also feed it a separate digital signal to run it through HQPlayer as well?
My current set-up:
Windows Computer running Roon Core/HQP Desktop 4
DAC: T+A DSD 8
Roon/Qobuz β HQP β T+A DAC (computer and DAC connected via USB)
Running independent from HQP: Spotify-Connect: Via Rpi/Ropiie computer with HifiBerry HAT. Connected to T+A DAC via optical.
Proposed Set-Up:
DAC: T+A DSD 8 connected via USB to computer running Roon/HQP.
Vinyl-> RME Babyface β HQP β T+A DAC (computer and DAC connected via USB)
Rpi/Ropiie β RME Babyface β HQP β T+A DAC (computer and DAC connected via USB). Note: I want to run Spotify-connect with the Rpi/Ropiie via HQP.
Thanks!!
