Internet: 100mB fibre optic to the house with Shell wifi hub
D-Link switch: Ethernet connection to Shell wifi hub
Library: Ethernet connection to D-Link switch
Aries G2: wireless
My digital system is:
music library: Melco N100 with ethernet connection to
streamer: Auralic Aries G2 with USB connection to
DAC: Rockna Wavelight
7500 albums in DSD, WAV, FLAC & MP3
The Aries G2 is Roon Ready and can be used as an endpoint. Do both the Aries and the Wavelight have to work with Roon in order to be able to use the upsampling and DSD conversion facilities in MUSE? See the screenshot below.
Thanks, Neil
Sorry for being a novice. I didn’t realise that the upsampling and conversion options were in the Custom dropdown menu. This is now working for PCM.
However, for DSD64 there is no option for it play in native DSD. When I use Lightning DS with my Aries G2, the track is played in DSD64. However, in Roon it is only played in PCM at whatever rate I set in Custom. Why are there no DSD options? Thanks.
Can’t say for sure but what are the dsd options in the G2 settings in roon? Maybe the G2 is not passing the DAC capabilities to Roon? Look under show advances in your first image posted above
Are you still having issues with this behavior or have you been able to resolve the DSD output for these devices? Do let us know if you need more assistance here.
