I want Roon 1.8, and all subsequent releases, to focus on pitch perfect reproduction of birdsong, and birdsong only. And the much undervalued sound of silent contemplation.
Yes, I can use roon as the front end following the setup where you Enable Squeezebox support in roonâs settings. And then Stack Audio uses commercial version of Ropieee and can enable Squeezelite. Then roon sees that as a Squeezebox connection. At that point I can transfer between the roon endpoint and the Squeezebox one even though it just the same streamer.
I could happily live with the Sqeezelite endpoint setting and it sort of sounds richer but the roon end point setting feels like has more space around instruments and blacker background. Maybe if I didnât have the mscaler,I choose Squeezelite. I might activate again just play with it a little longer.
Everyone afraid of noise crawling through the ethernet cable can simply use a Wifi connection. No cable, no noise and you can safe a lot of money for cleaning gadgets and Roon donât need to waste manpower to âimproveâ somethingâŚ
The following is from the 1.3 release notes. Here they discuss RAATâs network tuning. My reason for sharing this is to show some of the tradeoffs Roon had to consider to effectively pass a bit perfect stream. Perfection doesnât exist in the real world. Engineering always comes down to balancing competing needs. Achieving better sound quality might come at the expense of something else that Roon isnât willing to give up.
âWe found that using TCP reduces CPU load on the audio device and in the coreâprimarily by reducing the context switching overhead associated with âwaking upâ for each packet. Using TCP also allows us to offload work associated with re-assembling the packetized audio stream from RAAT to the operating system kernel on the audio device, where it can be implemented more efficiently and simply.â
âWe also found that TCP is a lot âfriendlierâ to poor networks and routers. Not all router manufacturers perform extensive QA with high-resolution UDP audio streams, but they all test to make sure Netflix and Youtube (both TCP-based) work. TCP is also less likely to create trouble with exotic network setupsâmanaged switches, jumbo frames, etc. If you have experienced trouble with these, itâs definitely worth taking another shot to see if the new protocol is easier on your network.â
The counter argument is WiFi causing more noise. But really Ethernet is better because no chance of drop outs.
I personally think all these differences are minor and shouldnât effect overall enjoyment. Itâs more of just tweaking especially if have a very revealing system. I would think direct connection to the core sounded excellent until directly compared to streamer connection. The differences in software are even more subtle.
I tend to disbelieve most of this stuff until I hear it for myself. Comparing Squeezelite setting to roon didnât cost me anything but time, so figured Iâd check it out.
I read that too as saying their choices were for a more efficient endpoint, which to me could be better sound quality. Didnât sound like they made sacrifices.
The bits in question are information, not part of a signal - signal to be read as processed data. Pure data is either transmitted and received or it is not. There is no interference through ânoiseâ that might alter the bits. Zero is zero and one is one. Full stop.
Timing is immaterial in network transmisslon. Data is buffered at reception and the DACâs clock will handle the timing. As mentioned before: this so-called noise cannot alter the value of either zero or one.
Music player is a sloppy definition since the actual âplayingâ doesnât start until the DAC starts processing the bits. How the bits get to the DAC is immaterial
This brings us to point 1): as long as the bits arrive it doesnât matter which protocol is used.
Point 2): cf.buffer and clock
Point 3): cf.value of one and zero
Perceived differences in sound may or may not be extant. If extant, the cause will not be the transport protocol but will most likely originate in the DACâs signal processing path, i.e. different internal routing of the signal depending on the transport protocol or some such.
Why does this pointless discussion always rear its ugly head?
So I only said that because Iâve come across in articles but I personally wouldnât go that crazy worrying about stuff like that.
Hereâs an article that mentions how could be worse but take with a grain of salt.
I think worrying about the changes software and noises make are almost for those of us with ocd. My system sounds amazing and with any of these changes, it still sounds amazing. Maybe just slightly different only if know what to listen for.
No, you took the wrong conclusion from what I posted. I clearly stated my reason for sharing. Iâll repeat it. âMy reason for sharing this is to show some of the tradeoffs Roon had to consider to effectively pass a bit perfect stream.â
But since you mentioned it, more dropouts means more retransmissions which could very well lead to noise that can degrade sound quality.
Because we are talking about sound quality. You yourself mentioned the different stages that the signal has to go through to get us sound. Noise degrades sound quality so any discussion about sound quality has to consider more than just the bits.
And no zero isnât zero and one isnât one. Generally these values are determined by comparing voltages against a reference voltage. When the signal crosses the lower threshold we get a zero and when it crosses an upper threshold we get a one. Noise can impact the detection of that crossing such that timing precision suffers.
The reason this discussion keeps raising itâs head is because a good number of individuals keep holding onto simplistic representations that bear no resemblance to whatâs really going on in the real world.
RF is well known to harm analog circuits and degrade sound quality. WiFi access points are essentially RF generators. Bathing the signal in RF is probably not the best way to reduce noise.
I hope you donât have a fridge in your house. They are much bigger RF generators even from a higher distance. And donât take a mobile phone inside the room you want to hear music.
