Volume Control doesn't work in 1.1 as expected
… but I can’t see any synchronization between Windows(8.1) and Roon 1.1.
I use the Meridian Explorer² and it’s app (the same as in the System Volume Control) as an example.
See the screeshots, and compare the volume values, please.
Thanks @cas – it looks like there’s a bug here :frowning:
If you’re using ASIO, we shouldn’t be showing volume control at all. We’ll fix this in a bug fix release in the next few weeks.
Thanks for the report!
Hi Mike,
in my case, Meridian Explorer² uses (USB) ASIO for audio and WASAPI for the volume control.
Hey @cas – build 55 is live with a fix for this issue. Let us know how it goes!
