I forgot to try removing the HP docking station but now that’s been tested as well. Unfortunately, the same results as before.
Hi @peter2,
Thanks for confirming you can control volume in-app.
When you tested out Fixed Volume, how did you test out adjusting the volume? Can you do this again, but this time test out changing the volume through the Apple Home app?
Ultimately, this issue likely comes down to our current support for AirPlay 2, which we’re still refining. We’re actively working on improving compatibility and ironing out the remaining kinks.
I’d test out the same thing above - enable compatibility mode, Fixed Volume, and see if you can adjust via the Home app.
Let me know if any of the above help!
