Hi @Luc_Bonte,
Thank you for your patience while we worked through the queue. Can you elaborate on what you mean by the volume control not working? Is the volume going to maximum on its own? Also, can you provide the date, local time, and the track playing when this problem occurs?
Hi Daniel, thank you for your reply. Problem solved, the audio settings were changed after the last Roon update. As I saw the changed settings when delving deeper into the problem I could correct them. Thanks anyway, Luc
