ok guys, quick update. found the issue and more importantly I fixed it.
preparing a release, so this will be resolved soon.
Thanks,
Thanks,
Thank you for the update, and fixing the problem.
As always very much appreciated.
perfect and fast work
thank you very much!
Amazing, thank you kindly, Harry!
Edit: All good here on four HifiBerry AMP2 installations after another restart like you said in the release notes (the initial update cycle reset the volume once more to 100)
What was the issue? Will update soon as I see the release available. Great work Harry. Much appreciated by my wife too. Hope wonāt scare the begezzus out of her or me for that matter when I forget to check it
chicken and egg.
Thereās software in place to store the mixer settings on shutdown and restore it upon boot.
Those settings are being stored in a file; however, if this file is not present itās being ignored.
So in the end it was rather simple to fix, but figuring out what exactly was happening costed me time and a some cursing
Excellent, so in theory I could just SSH in and create that file?
EDIT: or just let it update to 242
Looks good from my end Harry
Hello, When is the fix available?
Itās already out there for some days.
Thank you. I just installed it.
To be more precise, a restart of Roon will leave volume as it was before.
When restarting my Auralic Vega 1, then volume goes to 100% in Roon (and in Auralicās App). So properly an Auralic issues.
have you read the release notes? you need to restart your unit twice.
