Volume goes up to 100 when using setting Device volume
Hi,
after the latest update the (1353) the device volume setting does not work correctly. It increases the volume to 100% and is thus not usable. Instead I need to run on fixed volume and that is not the wanted situation.
I am running Roon on a Mac Mini M1 with Sonoma 14.1.1
Please assist.
Best regards,
Christian Rinman
Moved to Support. It may be helpful to Roon if you could also specify the streamer/DAC that you are using
