Hi,
Probably this topic exists already somewhere, but I was not able to find something.
Each time when I turn on my SOtM as network player which is plugged to a Minidsp the volume is at 100%, even after setup a safety limit to 50 in the settings menu.
How to solve this ?
Thx
beka
September 17, 2021, 11:14pm
2
Hey @Cedric_Courtens ,
It seems that there is a setting in your SOtM device that can help with this. Could you please check the device’s menu?
This thread might help:
Hello @Christoph_Eichenseer ,
The Kii Three with Kii Control does not support USB volume control, so there is no way to change the device’s real volume using Roon’s built in controls.
Roon’s DSP Volume (Software Volume in the sMS-200 settings) uses a high quality 64bit precision attenuation with dithering to the device’s native USB bit rate. While it is technically inferior to the device’s built in volume control, you may find that it sounds very good!
-John
system
(system)
Closed
September 19, 2021, 10:53pm
4
