Is there any way to have repeat volume up/down commands sent to the Roon server when a volume button on a remote is kept pressed?
I only see a single volume step via Verox, whereas when the FLIRC is connected to a Windows box the volume ramps continuously while the remote button is held down.
According to any AI this is a longstanding limitation in the underlying OS but I just thought I’d ask to see if there was any new news.
Good question, and it’s not really an OS limitation. Verox’s remote handler gets only “pressed” and “released” from the input layer. Repeating a held key is left to the software, and we only act on “pressed”, so you get one step per press. Windows repeats held keys for you, which is why the same FLIRC ramps there.
It would be handy for the user to be able to configure the volume ramp speed while the remote button is held, and possibly also the ‘safety limit’ as the overall delta for the ramp if the release event gets lost.
A further, unrelated, option could allow the user to adjust the size of a single volume step as an alternative to the current 1%.
You may already be thinking along such lines of course.
