What HDMI audio format does Roon Nucleus Plus output?
Roon Server Machine
Roon Nucleus Plus
Unifi UDM Pro SE
HDMI A & B each to a Dr. HDMI 8k then to an Anthem AVM 90
4,500
Anthem claims the reason I’m having issues with the Roon is related to EDID. I have purchased the nicest EDID managers I could find.
I need to set the audio format that is coming from the Roon Nucleus HDMI A & B. What format is that?
What are the issues?
@Isaac_Spear - I suspect that you have a chain of HDMI devices: Nucleus → Anthem → Smart TV.
It’s probably the Smart TV that is causing an EDID handshake issue with the Nucleus. I had this issue when we replaced a Panasonic TV with a Samsung TV
I believe that I just have the Dr. HDMI device set to its simplest HD setting (1920x1080) - nothing to do with audio formats.
