Orbi Router. Roon working via wifi …No problems w/ connection.
2022 Cambridge Audio DacMagic 200M DAC outputs to a McIntosh MA6600 Integrated amp
about 25,000 tracks …Mostly lossless. Roon also connected w/ my Tidal subscription
I’m not particularly knowledgeable about high-resolution audio, inc. bitrates, kHz, MQA, etc… But I’d like to know that I’m getting the most out of new M1 Mac Mini and DacMagic. I’ve read that MQA recordings on Tidal sound great but I’ve not been able to get them to play as such through through my system or at least the a MQA light on my DacMagic hasn’t lit up indicating it. Here’s a bit of what I see. Hopefully there’s to set it up so my DacMagic outputs the best quality possible given the inputed signal. thx so much!!!
You have to check full decoder and renderer for the 200M. In that way roon is just passing the file and not rendering.
Why are you using osX Midi Audio settings? You need the right settings on roon, and anyway for Ventura I see a lot of problems. Just give exclusive the dac for roon.
Now here are my screenshots, I little different because 2 weeks ago I did upgrade to a zen stream instead of M1 mini going usb to 200M.
You can disable Roon Core decoder, I do dsp so I think this is needed. The Sample rates for me are limited by Zen Stream, you can push PCM to 768 and DSD to 256 DoP (Macs do not support native DSD)
