Core is not recommended to be used on WiFi. For an endpoint it’s ok but still if you can lan wired connections always give minimal issues…. WiFi issues are often a plenty as it’s not a full duplex connection and often each device competes for airtime
Ben with the support team here, thanks for writing in!
As others have mentioned, testing over ethernet would be a good next step. With that, I’m not able to enable core diagnostics on your account. If possible, could you please reproduce the issue, and use the directions found here and send over a set of logs to our File Uploader?
Sharing the specific data, time, as well as track playing at the time of the issue would be helpful as well.
