Windows 10 - Roon volume not ramping with system volume control
Roon Server Machine
NUC running Rock, PC win10 remote
Direct wired to Orbi
Just the PC atm, connect to Logitech USB speakers
Roon volume is no longer ramping up and down with PC device system volume.
Device volume is checked and selected. This previously worked, prior to last update.
Any ideas I could try?
Hi @grizaudio,
Thanks for writing in - and sorry for the long wait in getting to your issue. What is your current status, are you still experiencing this volume issue?
If you disable Microsoft teams, does the issue still occur? If so, could you please reproduce the issue and share the specific date, time and name of the track playing when the issue occurs?
Once you let me know this info, I’ll go ahead and enable diagnostics for your account so I can review the logging for clues.
If you’d rather do it yourself manually, please use the directions found here and send over a set of logs to our File Uploader.
