Confirming the following Airplay devices stopped working properly after 1401/1407 update: Devialet Dione and Devialet Mania. (I also have Phantom II but which is RoonReady and thus still streaming normally)
Also, the simple workaround of clicking the middle of the song duration bar to get the Airplay speakers playing worked for me! Thanks for posting that.
Full form submission
· I'm having trouble with my DAC, speakers, streamer, etc.
What best describes the issue with your audio device?
Workaround for Airplay not working after Build 1401
Clicking on pause and then play did not start the music. Only when I click the track time bar does the music start playing (at the time that is selected).
I normally don’t use DSP. I played around with enabling various DSP features like headroom management and parametric EQ, but I still had the same issue.
Thank you, this works for me too! I have only one endpoint that is giving problems being ‘unresponsive’, a Lithe Audio ceiling speaker (5 y.o). But iOS/Mac devices can still AirPlay to it fine. Another endpoint, an older (12 yrs?) Monitor Audio M2, I have to press play twice to ‘get it going’.
The Lithe Audio speaker, when I press Play, it changes to a Pause symbol (implying playback has started) and the little EQ icon dances about as if playing, but nothing is happening. No output and no progress.
