I had that same issue, but it resolved after I restarted the NAS. The other problems have cropped up since - chronic hanging when accessing files on the NAS. Right now checking all the points on my network. Trying to isolate suspects now: extra data load after turning on DSP? Other router issues? In any case, the SonicTransporter seems to be struggling.
The sonictransporter is major struggling with my iphone remote.
It is literally going ballistic since the update . I open iphone app, it says failed to connect, then it will go to ready after several seconds, then it gets stuck on initializing
I could open the iphone app 10 minutes later and it may connect immediately.
I had tidal going nuts on the iphone screen and would keep flickering and not connect.
I have a mac and it has had zero issues with the update.
The linux Sonictransporter has turned into Linda Blair in the Exorcist.
Hey @Jim_Honsberger â weâve been discussing your issue and look forward to making some progress, but I didnât see your logs yet.
Did I miss them? If not, could you send over a Dropbox link, then we can move forward here?
Hello, I believe the problem is with the iphone ,ipad app . I can connect no problem to my sonictrasnporter from my mac computer all the time but if i try to connect to the sonictransporter with the iphone app , the app gets hung on initializing even though i believe the sonictransporter is working properly becasue i can connect with my mac.
I deleted the app and reinstalled and i see that the sonictransporter is ready to connect and i can successfully connect with the iphone app.
But after awhile , i will no longer be able to connect with the app and it will show initializing . Im sure if i deleted and reinstalled I could get the sonictrasnporter back to ready.
@Jim_Honsberger you really need to submit your logs in order for @support to do anything
I donât know how to send logs . please send me a way to do this in linux .I see roon server diagnostics but you cant just copy and paste it.
Hey @Jim_Honsberger â information about accessing your database is here.
Once you have access to the database, youâll want to zip up the logs folder and then post us a Dropbox link like @Eric mentioned in post #3.
If you have any questions, just let us know. Thanks!
Iâm also having problems maintaining a connection between Sonic Transporter i5 and Synology NAS.
The only way I found to restore the connection was to reboot the NAS, which takes about 5 minutes. Have had to do so 7-8x in last day.
Furthermore, on both Mac and iphone client the queue just disappears if I stop playing music for any length of time.
So this morning I installed build 194 on both Mac and ST Core. But now the Mac client is virtually useless: shows only the current playing track, but nothing in queue, and the play controls at bottom of page show only the information at time of launch.
Interestingly iphone app seems fine: current track and queue and play controls all function normally.
Whatâs up?
2 posts were split to a new topic: 1.3 SonicTransporter canât use USB disk
@cjbraon, @Jim_Honsberger â what is your netmask? (I have an idea)
I sent logs this morning
The only problem I have now is the iphone app hanging on initializing.
If i close the app out 4-6 times i can get Roon core on the sonictransporter to get to Ready.
your logs do not contain your netmask, i need your IP settings to know thatâŚ
Music Servers 1
sonictransport
Manage
Version: 2.3
Model: sonicTransporter
IP Address: 192.168.86.36
MAC: 00:E1:4C:68:1E:78
Network players 2
bedroomrendu
Manage
Version: 2.3
Model: microRendu
IP Address: 192.168.86.80
MAC: D0:63:B4:01:04:92
officerendu
Manage
Version: 2.3
Model: microRendu
IP Address: 192.168.86.25
MAC: D0:63:B4:00:EC:F0
Deleted âŚ
Subnet mask is 255.255.255.0
Using google dns server addressesâ too.
we think we might have an improvement here, that might help a few cases⌠build coming in a few hours⌠id like to know if it helps you at all.
I will let you know .
@Jim_Honsberger â 200 out, want to give it a shot?
