I had this problem on day one of Roon 1.8. After restarting my Nucleus Roon core, my RPi4 with USB connection to Meridian Prime would show up again. If I turned the Meridian Prime off, it would not come back unless I restarted my Nucleus. Finally, after a couple times of doing this, I rebooted my router also. About the same time, we all got updated to Roon 1.8, build 756. I have not had this problem since then and I can turn my Meridian Prime on and off and it reappears instantly, as it should.
EDIT: I just tested it again and it’s still working as it should with Meridian Prime turned off and on.
Hi, I’m having trouble getting my Chord Hugo 2 to show up in my audio devices in Roon. The issue is happening on a Macbook Air M1 running Big Sur 11.1. The Air is connected wirelessly to my Roon core, a Macbook Pro early 2015. This issue has developed since I updated to the new version of Roon.
The Hugo 2 is connected via USB cable to the Macbook Air and works just fine through OSX and the Tidal app. Roon recognizes that the Hugo 2 is connected and displays it under “This Mac” on the “Audio” setting tab in Roon. Is shows as “CoreAudio.” I have disabled and enabled it multiple times and tried resetting the “device setup” to defaults. “Private zone” is not selected.
Despite all of this suggesting there is nothing wrong with my connection to the Hugo 2, Roon says at the bottom of the screen that I have “No audio devices found.” Stranger still, I was able to add the Hugo 2 to a group with the System Output of my Core and successfully played losslessly to the Hugo 2 and the System Output. So Roon actually has no problem outputting to the DAC, it simply won’t display it as its own device in the player.
I tried disabling all the audio devices and then reenabling, but now I don’t see any devices available to play to, despite several showing as enabled in the Audio settings window.
02/14 08:53:01 Debug: NotifyCorruptZoneDatabases Exception LevelDb.Exception: IO error: lock /var/roon/RoonServer/Database/Core/f05024d5dd4f4d4e9e85cd849895d1a9/transport/zone_16012fd3a5f31d64c74b8382fbf6bde0fcd5.db/LOCK: already held by process
at LevelDb.Database._CheckError (System.IntPtr err) [0x00037] in <c495c7ebabb54b78a9ef13ecb1cd00aa>:0
at LevelDb.Database..ctor (System.String path) [0x00075] in <c495c7ebabb54b78a9ef13ecb1cd00aa>:0
at Sooloos.Broker.Transport.ZoneDb..ctor (System.String dbpath) [0x0000d] in <816381aafbe2495a9150b9060c285ec5>:0
at Sooloos.Broker.Transport.Zone..ctor (Sooloos.Broker.State state, Sooloos.Broker.Transport.Module module, System.Sooid zoneid, System.Collections.Generic.IEnumerable`1[T] endpoints) [0x0010f] in <816381aafbe2495a9150b9060c285ec5>:0
02/14 08:53:01 Error: [transport] emptying out corrupt zone database 22:1:f3a5d32f-641d-4bc7-8382-fbf6bde0fcd5
02/14 08:53:01 Critical: scx: in OnExit: System.NullReferenceException: Object reference not set to an instance of an object
at Sooloos.Broker.Transport.Zone._CancelPendingSleep () [0x00000] in <816381aafbe2495a9150b9060c285ec5>:0
at Sooloos.Broker.Transport.Zone._StopWithoutTouchingDatabases () [0x00007] in <816381aafbe2495a9150b9060c285ec5>:0
at Sooloos.Broker.Transport.Module.NotifyCorruptZoneDatabases (Sooloos.Broker.Transport.IZone zone, System.Exception e) [0x0005b] in <816381aafbe2495a9150b9060c285ec5>:0
at Sooloos.Broker.Transport.Zone..ctor (Sooloos.Broker.State state, Sooloos.Broker.Transport.Module module, System.Sooid zoneid, System.Collections.Generic.IEnumerable`1[T] endpoints) [0x00133] in <816381aafbe2495a9150b9060c285ec5>:0
at Sooloos.Broker.Transport.Module.NewZone (Sooloos.Broker.State state, Sooloos.Broker.Transport.Module module, System.Sooid zoneid, System.Collections.Generic.IEnumerable`1[T] endpoints) [0x00000] in <816381aafbe2495a9150b9060c285ec5>:0
at Sooloos.Broker.Transport.Module.ev_threadexit () [0x009fe] in <816381aafbe2495a9150b9060c285ec5>:0
at Sooloos.SynchronizationContextThread.OnExit () [0x0000a] in <2b8464ac30eb4403a9ac8d3163052362>:0
I have this issue only on my work Macbook Air 2015 as endpoint with DAC attached every other endpoint no issues. DAC in this case Hiby R5 drops off, I can see it in devices but Roon won’t see it as a zone. It worked initially but I changed one setting in device settings and it them started this behaviour. Reboot of core restores it temporarily and then it drops off again.
Same here. Pi4, DietPi, RoonBridge. Need to reboot the core (on Synology) whenever the DAC was switched off. Before reboot of the core i cannot select the bridge in zone picker. Grouping the bridge with another zone works as a workaround.
Same issue, though 3 Ropieee endpoints, 6 Chromecasts and 4 Airplays are all visible. It’s only the Schiit Modi 2 Uber connected to my Mac that is not visible as an endpoint, even though it appears in the settings. Rebooting the Core (ROCK on an Intel NUC) tends to make it visible again. Roon remotes have occasionally lost the Modi in the past, so this might not entirely be a 1.8 issue
I am having same problem, the DAC just disappear from audio zone. Using MacBook Pro with local USB DAC, it is appearing in Mac sound setting and no issue, Roon found it in Settings → Audio, but Audio Zone cannot select at all.
I have this issue with 3 Ropiee (RPi) endpoints. I noticed that for me it only effected the ones using USB to connect to the DAC. In Ropiee I disabled “Dynamic Audio Power Mgnt” for USB that I think was enabled by default. It’s only been 24 hours, but so far no more issues.
“I have this issue with 3 Ropiee (RPi) endpoints. I noticed that for me it only effected the ones using USB to connect to the DAC. In Ropiee I disabled “Dynamic Audio Power Mgnt” for USB that I think was enabled by default. It’s only been 24 hours, but so far no more issues.”
I am going to give this a try, but I also have the problem using VitOS as well.
I’ve got the same issue. Running Roon on a Nucleus+. Since upgrading to 1.8 I keep losing zones including my Mac Pro, a couple of MacBook Pros, iPads, iPhones.
Additionally, in my case my NUC to Oppo HDMI IN is always visible but when I play any music to it Roon doesn’t recognise it being played even though I get sound out of the speakers. Seems like a major bug introduced in 1.8 and one that is making Roon completely unusable for me. My core is on a Synology NAS and I have to login to the web interface and restart the packages he time.
Hey Roon, get your act together on this one. Devices show up in Audio but not in the drop down list. This happens with multiple devices. I am not constantly restarting my Zen Mini.
