Hi @dylan, @Louis_Richardson , did you solved this problem? I am experiencing the same issue and the setup is very similar. Thanks in advance!
Are you experiencing this will all remote devices?
A while ago, I switched to an iPhone. I’m sorry, but it’s been some time, and I don’t really remember if the issue got truly resolved. If I remember right, the situation improved, and became less of a nuisance, but I don’t really remember what I did. Good luck.
