Intel NUC I7 8th gen running latest Roon build
Linksys Velop mesh WiFi network
Auralic Aries G2 connected to network via Ethernet
I have the Auralic Aries G2 and I would the option to have the Aries G2 Audio setting be controlled through Roon. As of now, if the G2 is in sleep mode, it is not shown as an available audio output source in Room. I then have to switch from the Roon app and then open their Lightning DS app, then go into settings, then go to power management and change from sleep to resume.
If I want to keep the G2 as an active audio output source in Roon, I’d have to keep it on all the time BUT I would then have to change the display setting so display wouldn’t stay on all time and potentially burn in the screen. But I want to see album info all the time WHEN I do use the G2.
I’d like it to be how all the other audio settings are available in the Roon so I can switch to any source I want. Would seem like a somewhat simple software/coding solution.
