nucleus connected to Devialet 250 via ethernet ( apple router)
devialet 250 connected via ethernet
I start via ipad roon to play music, devialet powers up as it should but then I get message ‘audio device in use’.
I need to restart nucleus core to make it work.
Not a major problem but still annoying…
I have only one endpoint (devialet). Indeed initially I had kept my ipad as second endpoint ( and even used it now and then) but got rid of it because I thought this could be the reason for the problem.
firmware on my 250 is as up-to-date as it can be given that I have not (yet) upgraded to 250 pro.
If you activated Ethernet input, you don’t have multiple options on source remote button? I do have this on my Expert (UPNP, Roon Ready, Airplay, Spotify, Air etc.).
I could indeed put USB wifi line etc input but I desactivated this via devialet configurator as I use only ethernet. But indeed putting another source input might allow me to solve my ‘Audio device in use’ problem
I have the same setting in configurator (one input only - Ethernet). But, when I press “Source” button on remote, I have multiple Ethernet sources on display. They are all Ethernet inputs, but different protocols (UPNP, Roon Ready, Airplay, Spotify, Air etc.).
Did you tried to press “Source” button on your remote?
I avoided using any other app to control devialet. Still it is telling me ‘audio in use’.
Not sure whether pertinent but normally this happens if I play something in say the eveningand then want to play something the next morning…
The problem occurred again today 17-03 at 09.50 Central European Time.
I restarted the Nuceleus and after it worked again. The problem mainly ( I think even exclusivly) occurs after I have not used the Nucleus overnight ( but again sometimes it works even after a night of non-use).
I repeat it is not a big deal but I am still curious to know why.
Thanks for your patience while the tech team looked over the logging information.
What we can see via the logs is that the device is sometimes failing to respond back to Roon when it returning from standby while buffering a track:
Trace: [devialet] [9] waiting for power on...
Trace: [devialet] [9] power is on!
Trace: [zone devialet] Unsuspend
Info: [devialet] [zoneplayer] Open Result (Playing):Result[Status=Success]
Info: [devialet] [zoneplayer] Performing initial seek to 157000
Info: [devialet] [zoneplayer] Starting playback
Trace: [devialet] binding feedback socket
Trace: [devialet] ==> success
Info: [zone devialet] OnPlayFeedback Playing
Trace: [devialet] [Lossless, 16/44 FLAC => 16/44] [100% buf] [PLAYING @ 2:37/6:32] Money - Pink Floyd
Trace: [prebuffer] ready 149940/441000 (34%) @ 157/392 sec
Info:
Trace: [devialet] device in use (feedback timeout)
Trace: [devialet] releasing feedback socket
Warn: Track Stopped Due to DeviceInUse
I suggest that you reach out to the Devialet support team with this report, based on the logs shown above it appears that the device is at fault for not returning the proper status to Roon when returning from standby. We’re here to assist if they are unable to find the cause of this behavior.
When this occurs one of your devices is using the endpoint. This can be one of the computers or Macs hat have been using the endpoint, although the are not playing at the time. I have this problem when I have used the Mac to play Youtube to the Devialet 250 Pro and I have forgot to switch the speaker back to “Internal speaker” afterwards. Try to control the little speaker icon on top and switch the Devialet Air or Devialet WiFi to internal speaker. Let me know if this solves your problem. Philip
