TEXT GOES HERE
NUCLEUS
Nucleus rev B - SN: 54B2039B989F
Barcodes : 3951082072
6LP040
TEXT GOES HERE
Ethernet
TEXT GOES HERE
Amplifier Cambridge Audio CXA81
Remote: iPad air 4 2020
TEXT GOES HERE
Since the 1.8 update Roon app on remote CANNOT find the Cambridge Audio amp. when I want to stream music IF I did not desactivate it at the end of last hearing in the audio settings. If I did desactivate it, there is no problem.
The problem is not related with the iPad as Roon app reacts equally with a Samsug phone or an Acer PC.
As a result I have to go to the audio settings at the end of any hearing to desactivate the Cambridge Audio. If I don’t do it the only way for me to use the system again is to go to System Status, to reinstall the Operating System and to restart the Roon Server Software. Obviously I’ve had to do that several times since last week.
Before the update, there was no no problem at all.
Apart from that, listening music through Roon is really great!
Thanks in advance for your answer.
Gerard
