FritzBox 7490 via Ethernet
audionet DNA via Ethernet
Synology NAS DS213 via Ethernet
roon settings / Audio: only PC soundcard , no audio device found
but audionet DNA is shown in windows network and shown in FRitzBox network and operates perfectly in network and with Remote Control Point from windows PC
It looks like this device can be streamed to over the network via UPnP which is not a supported audio device in Roon. It looks like you can play to the device via USB as well — Have you tried playing to the device from Roon in this way?
Thanks for the quick answer. In fact its connected via UPnP. I will try your suggestion.
But even if it works it would be even better, if Roon could be updated to connect via UPnP. Is there any hope to it?
