Daniel,
Thanking you and the team again for pursuing this…
As I said the other day, I have the impression that I first noticed this happening 9 times out of 10 when the Roon architecture changed to the separate Server; that was November, wasn’t it.
Unfortunately, that was when I also bought my Nucleus (Black Friday
!); and so when the location of Roon Server/Storage etc changed from my iMac Pro to the Nucleus. At that time I was able to save then re-import from my Roon database backup - as described here etc - without error.
Since then I’ve probably doubled the size of my Library - to over 10,000 tracks.
Hmmm; I’m feeling that it’s not really practical to re-import and retag etc in Roon 5,000 files, is it?
Again, my apologies for not completely understanding, please, Daniel this:
If, say, there was a ‘corrupt’ (or otherwise ‘misbehaving’) file that was one of those 5,000 new ones, imported, say, on January 1, is it the case that Roon keeps trying to rescan it every time I import a new set of files/tracks; and that it somehow works its way into a position fifth from the (‘new’) last file in my Library?
What’s more, I’m certain that several times (since November) the Analysis process has finished. And recently. Doesn’t that suggest that, if there is a faulty file, it has at least once successfully made it past the stall?
Not trying for a moment to be ‘contrary’; grateful for your help
! Just trying to follow the most productive path. Thanks.
