Thanks for uploading logs @Phil_Ryan & @Margaret_Charlton, no conclusions just yet but I will keep you in the loop. We did make some server-side changes to live radio two days ago, have you had any hiccups in the last 24 hours?
I’ve been playing BBC Radio 3 for 7 hours without interruption. I had issues some days ago but I understand Roon was working on back end changes at the time.
Is your Roon Core connected via WIFI or hardwired ? I have a secondary Roon Server on my laptop connected with WiFi, and it can be unstable when streaming some Live Radios.
Mine is all wired, I can stream Tidal to the same speakers and its fine, using Sonos is fine, other radio stations seem fine its just the BBC ones that seem mainly affected.
@Joel@kevin Mine currently is not chopping off, but stops playing after 30-40 mins even though I have no timer set and my Mac is set for the hard drive not to sleep.
@kevin
I suspect that the pbs are caused by AAC streams and not MP3 streams. BBC decided to go for “HLS” technology for AAC stream, which is not rare but uncommon. Audio players should of course support this but maybe Roon has become more sensitive to it recently… @Margaret_Charlton do you have dropouts if you select a BBC MP3 stream to play?
I get dropouts no matter which BBC stream is selected, however if I try radio Paradise as @Margaret_Charlton suggested then its fine, this seems to be a flac stream.
Not sure if Roon have a requirement or ability to convert to flac to obtain good streaming.
Can you try this relay stream "MP3 129kbps"I have just added and check if there are still dropouts?
Sorry I am not in the UK so can’t relay AAC 320kbps as it’s geofenced.
Very frustrating for you.
I’m based in Surrey and the BBC Radio 3 320 feed is absolutely fine. It’s been solid for months and recently has shown the meta-data.
I have a basic Virgin Media router connected to several passive routers across the property. At every Roon endpoint, Radio 3 works perfectly.
I can only think it is a networking issue - either to your property or within it.
Annoying, but I’m not sure it’s a Roon ONLY issue.
