Roon Core Machine 1
Imac 3.5 intel I5, mac os 11.6.5 Big Sur. 24 gig RAM
Modem is Aris TM1602
Amplifi HD router Hard wired to blue sound node 2i as RAAT
Node 2i is connected to an Anthem AVM 70 via COAX from node 2i
Blue sound Pulse mini connected via wifi
5151
I have been having audio drops and at static while using Roon only. This happens very frequently. if I group the BlueSound Pulse mini and the node 2i the audio drop and static is only produced on the node 2i system. if i switch to the BueOS app, and not use roon everything works fine. I haven’t made any network or gear changes, It has worked fine in the past with this system and I’m not sure why this started happening. Any help very much appreciated.
