The Colors and Lights pallets are very bright in the new upgrade , the only change you can do is to change to light or dark palettes still not any good compare to earlier versions, comment or experience in this matter ?
What device, what OS, what GPU? Can you confirm that you’re running build 528?
W10 , INTEL®CPU 1007U @ 1.50GHz
Version 1.7 (build 528) 32bit
Please make sure that you use the latest driver for your GPU.
If this does not fix the problem, click on the pencil right of the thread title and change the category from Roon Software to Support so the support people will take notice.
Thanks, should check if this helps. For me it got much worse, from black to light gray, don’t like it at all.
Unfortunately, the update of the graphics card did not help, is very disappointed with the changed tone of the color.
Intel® HD Graphics for 3rd Generation Intel® Processors I guess as it’s a
have made some adjustments to the graphics card, did not become as before but I have to live with it.
Hi @IVAN_VALENCIA,
Would you kindly use the directions found here and send us over a set of logs using a shared Dropbox link? Thanks!
