I had a problem with my routers which is now fixed. Now Roon can’t identify any of the devices on my network. The only possible change I made was to the name of the network.
I’m am running OSX 10.14 and the latest version of Roon.
There used to be a way to add and delete Roon endpoints, but it’s disappeared or I can find it.
Just to verify here, the only issues is with wirelessly connected endpoints not showing in Roon, correct? Are devices connected via Ethernet visible? Are remote devices able to control Roon like normal?
