preface, feel free to skip: I thought this would be simple, but it’s appearing to be very complicated, and may need multiple conversations to handle my full setup in various rooms (2x 5.1s, projector, great sony bravia’s with unused atmos, a plethora of wireless speakers), but will concentrate on the traditional hi-fi setup in my home office first.
Currently, a very simple entry level setup, a couple of dali stand mounts, an onkyo amp, and a chromecast audio in to the amp.
Music is 100% streamed from either mobiles (tidal mqa, usually downloaded to device) or via pcs using roon. Vinyl setup I’ll disregard as concerned with digital only here. Other members of the house just cast from whatever they’re using (spotify, youtube, bbc sounds, whatever). Obviously have access to higher quality audio but the chromecast audio can’t handle it and cap’s out lower than I want. For context the entire house has gigabit networking + a great wifi setup with 8x wifi points.
I feel that I need a good DAC and a way to get the digital audio to it wirelessly without complex apps. Then hopefully I see the short comings in my speakers and can replace them, then likewise the amp. Budget is ideally ~700 but can go higher or lower as required.
Considered 2x cambridge audio devices, their streamer and their dacmagic + something else. Gut says the streamer I’ll find frustrating and the DAC will be over priced and that there are better I just don’t know about. Considered a node but being so locked in to one integrated solution or replacing half it’s functionality later doesn’t sit well. Considered Wiim Pro if I can get one then (insert DAC here?).
If I can get this bit right, get the music wirelessly from whatever I’m using to control it (roon, tidal etc) to an am via a decent dac, then I’d like to keep that bit of the puzzle and upgrade other components as I can get away with it.
Can anybody shed any light, as it appears I’m seeing two sets of feedback, great praise on cambridge streamer / node etc from whathifi and the likes, then tech posts on avr and other sources showing all the failures compared to other things.
My only requirements are to be able to take full advantage of higher bitrate audio, and do so without 40ft of wires. Help?
