Composer as a vital track detail not shown on ARC
I am listening on ARC to
Roon on Desktop says clearly it is by the composer Emil Szymon Mtynarski. This composer is not that well known (to me), so it would be helpfull to see this info while listening to the track.
But when I listen to the track via Roon on Mobile (ARC) I see only the following:
No mention of Emil Szymon Mtynarski. :unamused_face:
Anyway I can fix this by changing metadata? Or can Roonlab fix this generally?
While it’s true that the “Now Playing” screen on ARC does not show the composer credit, the Album screen does:
Adding this credit to ARC’s Now Playing screen is something that only Roon Labs can do, so I’ve moved this thread to the Feedback > Feature Suggestions category.
If this feature suggestion is important to you, please vote for it by using the Vote button at the top of the thread. Thank you.
grafik
AFAIK is there this longstanding (and so far never fixed) issue that composition credits don’t show for the first part of a multi-part composition in Roon. Maybe its just the same for Roon ARC too? See for example:
PS: If so then it is a bug in ARC too and fixing bugs shouldn’t require a feature suggestion.
@BlackJack - the credits show up on the Desktop/Tablet version of the Now Playing screen, but they never have on the ARC version…
I suspect it’s lack of real estate…
Thanks for moving the post. Yes, it is somewhat a feature request.
