I am using a MacMini with Roon server but the audio signal then goes out usb to a primate DAC 30, after about 6 o 7 minutes. Why?
Tanks for your support!
Best
Simone Bucaioni
Thanks for sharing your report, @SIMONE_BUCAIONI!
To start, may I kindly ask that you please provide a brief description of your current setup using this link as a guide.
May I also ask that you elaborate on the issue you’re experiencing a bit?
- Are you only having issues playing to this one particular DAC?
- Just to clarify, after several minutes playback is stopping with this DAC?
Regards,
Dylan
