Dell Precision 3500 server. Vortexbox Version 2.5 running Fedora Linux 25.
Roon core 1.7
Talk Talk Wi-Fi Hub ADSL modem/router Sagemcom CS 50001. Device Ver :FAST 5364-3.T8
Cisco Catalyst 2960 ethernet unmanaged switch.
Roon control on Ipad Air WiFi connected. 2.4GHz
Roon Control on HP Laptop Windows 7 WiFi connected 5Ghz
Roon control on Iphone 5S wifi connected 5GHz
Devialet Expert Pro 440 CI connected by ethernet cable.
Opening roon core on all the above control devices I get a message for one to two seconds ‘waiting for remote core’ ‘select another core’ before normal working. I get this every time I open Roon control.
Selecting Qobuz results in a red box warning for one to two seconds ‘Error loading page, please check network connection’ , the same when selecting ‘Albums’ from the menu.
There is no fault with the network or my wifi connection. download speed 71MB/s upload speed 21 MB/s. I have tried re-booting everything, modem/router core server, Devialet 440, laptop, ethernet switch and ipad/iphone. Tried different ethernet cables.
I installed roon core on another Fedora Linux 25 PC on a short Ethernet cable close to the WiFi hub/modem/router. Still the same problem.
This has happened in the last fortnight, I was hoping it was going to be a short term problem, but it seems whatever is causing the problem is here to stay.
I’d like some guidance on a possible solution as its getting very tiresome now and I’m considering alternative options to Roon. I’m looking at Auralic Aries as a possible solution and dumping Roon altogether.
