Constant problems while streaming from Tidal
Mac Mini. Core i5 2.3 Ghz 8GB RAM 128GB SSD. I am using lates Roon version (build 884).
Cable Ethernet connected to home router (TP-LINK).
USB SMSL M400.
< 1000.
  1. I got an “Can’t login in tidal message”
  2. Even if Roon CAN login tracks can’t be played!
This happens from time to time. Sometime it is imposible to login for few hours. Sometimes only few tracks can’t be played sometimes almost all of them.
Native Tidal app is working, but Roon don’t.
I would try logging out of all instances of Tidal, removing Tidal from Roon and adding it again. Seems to fix similar issues for other people.
Hey @Alexander_Shelkovski,
Thanks a lot for letting us know of this — we’re sorry about the trouble.
What @Graeme_Finlayson suggested, we would have suggested too as a first step. Did you get a chance to try this?
P.S. Thanks @Graeme_Finlayson :pray:
I tried to disconnect Tidal from Room, but the issue wasn’t fixed.
Thanks @Alexander_Shelkovski,
I appreciate it. Seeing that the issue is fairly recent, I wonder if it’s not related to this:
