Rash
Understand youāre situation is different than mine, therefore we both have differing views (nothing wrong with that).
For us in Perth, Australia, we only had a 2 day window (3rd / 4th April) to have our amps upgraded, with this being carried out at a local dealer. When I took my amps in for the upgrade I got a chance to talk to Olivier the Devialet technician who was doing the upgrades. Nice guy, but he couldnāt say much I didnāt already know (appreciate he was restrained due to Devialet employee confidentiality).
Got my amps home after the upgrade and then the problems started. No problems previously using Roon with my Proās (after the Roon Air upgrades), but now numerous issues. Also having problems with my Sub not playing as it did previously (wouldnāt trigger on), so this one not down to Network ānigglesā like Roon / Spotify / Airplay.
2 days after the upgrades completed in Perth Olivier left Devialet (to pursue other avenues), so the only person I could speak to directly left Devialet. Now Iām back to having to use Devialet customer service, and getting the standard PR bulldust.
Iāve been emailing Mathieu Pernot (Devialet Chief Engineer), but only getting limited replies and info. Was hoping that this would be an improvement, but the info gained here on Roon forum and via Devialetchat is 100 times more info Iām getting from Devialet direct. Itās great that all you and others can help with advice, but really is a major downfall that Devialet themselves canāt help.
Olivier Pacteau (Director of Customer Experience and Quality at Devialet) has been especially a major disappointment regarding feedback. He is the Olivier who writes (infrequently) on the Devialet Core Infinity logs, but hasnāt replied to any of his customers comments and itās now been over 2 weeks and nothing. If thatās how Devialet think theyāre going to improve their āCustomer Experienceā, as Olivier is the Director of that department then he really is an extremely bad example to the employees who report to him (maybe thatās why Devialet are so bad if heās the one in charge of Customer Experience - enough said).
I myself work as a Quality Manager, and previous Project I worked on was a $50Billion Gas Plant Project for Chevron here in Australia. If I had acted the way Olivier does then I wouldnāt have lasted long in my job.
Ok, rant over.
Going back to the title of this thread, I swapped over my amps from Master to Companion & vice versa, I havenāt had the āTransport: Device In Useā error since. Now it may be that something had happened to my Master amp during the CI upgrade, where the Companion was ok (my amps are actually 2 x 250Proās so both actually Masters, but have to assign one a Companion for 1000Pro config set-up). Realise this wonāt help others, but if some have a mono set-up itās something else to try, on top of your suggestion to set static IP address for the amp.
Hope you have a good weekend
Cheers
John
