Ah ok, leave it alone for a day or two and see how it gets on.
will do - need some sleep now. Thanks so much for your help!!!
Most of those servers are pointing to Google load balancers, but they do change once in a while.
I would not hard code them in hosts or one day the IP will change unexpectedly and we’ll release an update at the same time and the update will get blamed!
The good results are without a change in the host file. The file is back to normal and the last results screenshot has good and fast values getting to roonlabs.
The issue that started all this still exist - yet not as bad anymore.
So there is still something that is not right
Are my logs better now on your end?
little steps and all that, have you tried installing ROCK on the NUC?
I already have rock on my other setup, in another place.
This nuc I would like to keep with windows.
Up until 2 weeks ago this was never a problem, been running it like that for a long time. All I want is what I had 2 weeks ago ;-))
