Babylon Bee is awesome - and you are absolutely right: what their satire says is quickly becoming truer than reality.
I hope you feel better soon. Take care.
[/quote]
Thanks David. Probably just pre-trip anxiety, esp in these times - first pandemic flight for me tomorrow. But by the afternoon should be sitting on a beach in Kauai with the family, no audio forums, cables or DAC’s in sight. I find getting away from your audio system for awhile can be the biggest ‘upgrade’ of all. Unfortunately in order to get to Kauai at the moment one has to do a coronavirus test 72 hours in advance - which for for four of us cost more than all the cables in my two systems combined. Priorities… (and yes, I know we shouldn’t be traveling for pleasure at the moment, but if nothing else it will at least get our 12 year old out of his room for a stretch, and we have old, old friends there).
To conclude, some of us are so lucky not to suffer from psychological disorders, and have the ability to hear music properly in the subtlest of gradations. We are so fortunate, it turns out. So some of us can verify changes to SQ from power cables.
Sounds like it’s going to be a good trip. I hope you enjoy it.
Safe travels!
Aaaah, welcome back. How was your sleep? Rested and full of power I see. Here in Europe we are quite bored. We almost concluded and closed this topic without you.
We missed you
Jan, my wife and I love travelling. Post covid, I will bring my Furutech Flux 50 filter for a quick demo in your system, when we hit Europe again
Is this relevant? It’s good to hear, but nobody has suggested that psychological disorders might play a part.
Yep, hopefully most of us.
That was fine, right up until you used the word ‘verify’. Verify: to make certain or prove that something is true or accurate. As most of us remain stubbornly uncertain, and there still isn’t any proof, I suspect the phrase ‘think we hear’ might be a better choice than ‘verify’.
This thread has strayed so far off-topic and is laced with so much incivility that I’m not even sure where to begin moderating.
The off-topic back-and-forth hasn’t improved the discussion, and it’s blowing up the post count which can ruin the experience for others.
So let’s switch to slow-mode to encourage more considered responses. Please remember to stay on topic, and keep it civil. Thank you!
The lack of civility was quite off-putting. I admire your restraint. Thank you for the redirect.
Under normal circumstances, the ground wire, or CPC (Circuit Protective Conductor) as it is known here in the UK should not be carrying any significant current. It is solely there for the purposes of electrical safety to shunt fault currents to earth and interrupt the supply via earth leakage detection, or worst case via the appliance fuse(!) Anything exceeding 30mA here in the UK will cause the residual current device (RCD/RCBO) for the circuit in the consumer unit to interrupt the supply.
another aspect. Talk to the pro-audio guys. Literally those who create the music some audiophiles find only consumable through $$$$ cables. No fancy stuff there. Almost never. Decent, say Mogami products, yes. Never at a price point that is being discussed here.
Guess why?
I work with pro-audio guys in large and small studios. I know small studios who have very expensive cabling. Andy Jackson, Pink Floyd engineer, uses expensive cabling at his own mastering studio and at David Gilmour’s Astoria boat studio. Large studios tend not to. I have asked this question…Why?
(1) they are run as businesses and they buy thousands of metres of cabling. The procurement people will ensure the cable is cheap.
(2) Furthermore they have a lot of staff - if you put a cable worth hundreds of pounds into a studio which many techies and clients reside in, it may not remain there.
(3) strange though it may seem to you but fewer engineers than you might expect have great audiophile ears. Remember these guys have come up through a technical education and are good with tech. They are not trained to have good ears. They are engineers. Do not expect them to hear or care about the subtleties of ‘air’, of PRaT, of holographic sound. Just listen to the brick-walling of a lot of post 1995 mastering and you will understand that not all engineers understand the essence and subtlety of high-fidelity musical reproduction.
But some do. Speak to the aforementioned Andy Jackson and you’ll hear an audiophile engineer speak sense. Here he Paul White interviewing Andy in Sound on Sound magazine…
Having a recording studio on a boat must throw up a few unique technical issues, especially where grounding is concerned, and I wondered whether the Astoria was equipped with a copper anchor! “I’ve always thought we should just ground it straight into the river but no, we have gone to great lengths to optimise the electrics there, including fancy cable and the whole works. I do the same here in my mastering studio — it’s all esoteric cable, exotic mains leads and a special braided grounding cable. No doubt I’ll be shot down in flames about this, but when I changed the regular earth cable for the woven one it sounded better, even though the grounding was electrically fine before.”
I was interested to hear this, as we’ve tried to do listening tests on cables in the past and we sometimes hear quite big differences, but the results are hard or impossible to replicate when you take the cables to a different studio. “Absolutely,” agrees Jackson. "I’ve found exactly this when I go to James Guthrie’s place in Northern California, being pretty adamant about how I want to do something because it works at home. Then we find it sounds totally different in his room so we have to come up with a different solution. That’s really annoying because the subject of cables is such a minefield anyway! I’ve got to the point where I just call it voodoo and let somebody else worry about the physics behind it. I set myself up to be shot down in flames and then just ignore the people who are doing the shooting!
Hmmmmm…
We have explained countless times that anybody who cares to listen will hear differences, we do not understand why. So his comment makes perfect sense. Yes we know many will so badly want to believe its due to external factors, we get it. @Duckworp , excellent post
So when you hear new sounds and voices by using a nice audio cable, you are called an audiophile. When you just hear new sounds and voices without an audio cable, you are called nuts.
(Just messing around, not taking sides, not meant to offend)
Sounds to me like a really good example of external factors. You can hear a difference in one place, but not another. Changing the location (which is an external factor) changes the sound.
Let me give you a different example. Imagine a pharmaceutical company bring out a new pain killer, but they state that it will only work at home. It won’t work if you take it on a bus, or in a park, or in a recording studio. Just at home. Would you buy it? No, because you’d probably decide that it has no pharmacological properties worth mentioning.
I don’t know if this has been mentioned in the preceding 842 replies, but given that most buildings use regular electrical cable behind the wall and cheap outlets into which you plug your equipment, how can a quality cable between the outlet and a piece of audio equipment make a positive difference? I would have to conclude that this is snake oil.
It may have been touched upon
Of course it is snake oil - many of us have already expressed the same scientific fact around here, i.e. that a short piece of “premium” cable will not fix anything or replace those hundreds of meters from the normal grid, in so far as “clean” energy is concerned (not the latter means anything to SQ anyway).
