HQPlayer no Devices Found (Network Audio Adapter)
@jussi_laako - will do in a few hours.
Sent. Let me know when you receive it please. I sent to info@signalyst.com
I have 7055-Cs between Up Gateways and two Holo DACs, Spring 2 KTE and May KTE, zero issues.
What’s the latest @Suneel_Shorey :grinning:
Seems like 4070 Ti is reasonably priced and better than 3080 Ti I previously mentioned.
Better late than never……Took me 2 years……but finally pulled the trigger on a dedicated machine to run HQ Player!
Specs
Intel(R) Core™ Ultra 9 processor 285K (24-Core, 76MB Total Cache, 3.7GHz to 5.7GHz)
NVIDIA(R) GeForce RTX™ 5080 16GB GDDR7
64GB Dual Channel DDR5 XMP (2x 32GB - Black) 6400 MT/s
1000W Platinum Rated PSU, 240mm Liquid-Cooled CPU & Clear Side Panel
2TB NVMe M.2 PCIe SSD
I hope with this spec, I can finally run DSD 1024 through my Dac200. Just need to figure out whether Embedded HQP is the way to go and also how to do CUDA offloads as I’m tech illiterate in Windows as I’m a Mac guy.
Machine comes in 2 weeks time!!
For CUDA offload you need latest Nvidia drivers installed. And then from HQPlayer Desktop it is just checking one box in the settings.
On Embedded (Ubuntu, Fedora or Debian), it is enabled by default at HQPlayer side. But the Nvidia drivers need to be installed there.
Embedded is good if you are somewhat familiar working on Linux command line to get things installed and maintained (just terminal).
Thx! I’ll probably stick with desktop as the technical side is probably beyond me to install the embedded.
Will update once I’ve got everything set up. It’s a significant investment in a dedicated machine but I’ve been hooked on HQP and the interactions with you, Jussi for the last few years. There is no better way to go!! Amazing job - congrats!!!
:slight_smile: jussi_laako - I’ve just gotten my desktop setup. Is there any way to transfer my Mac license over to the new windows machine or do I need to purchase a new license. Ok either way - just wanted to clarify. Also, is v6 coming anytime soon…:slight_smile:
You can easily transfer HQPlayer Desktop licenses. You can remove key from one machine through the option in HQPlayer’s Help-menu and install it on another one.
Just completed it - thank you!
I just tried to play DSD 1024 with ASDM7ECv3 and it stutters with my new setup….:frowning:
I must be doing something wrong….
Not surprising though… I wouldn’t worry about this too much though, unless you specifically want that.
How’s your HQPlayer settings Advanced-tab?
I bought a Topping HS02 just for fun to test it out, and damn it’s broken. Last Topping product I’ll ever buy. Should’ve listened to @jussi_laako
edit. haha it started working after all
Bought the Topping HS02 to go between my computer and DAC. And surprisingly, it actually makes the music sound a bit darker somehow. Like it cleans up the background. I only got it 'cause I always use my PC directly without a streamer in between. And nah, the power’s fine - that wasn’t why I bought it. Down the rabbit hole we go, huh? :smile:
