I’m doubting these small meters have enough capacity to induce 5333hz into a whole housing estate of hundreds of apartments. There are no electronic meters at the apartments only in the sub room that I have found.
It’s much more likely a motor or other high current controller radiating or affecting the mains and its the mains acting as the antennae if you like.
Ok. Digging a little further. Mega Power Automation also seem to be linked to solar power. Does the estate have PV panels on the roof? If so the inverters might be implicated…
I have garnered the attention of the power supplier’s technical quality and transient management team so more will be coming. Meeting them later next week. This should be fun
Actually the noises are worse when you get a better recording…some of this is not coming through to the speakers however - this is recorded free air with a wire to the input of my ADC (Focusrite Scarlett Solo) just ignore the lower 100Hz noises and focus on the clicks and tones. easier with headphones on.
just an update…the power guys bailed on their appointment due to risk of cover-19 a few days before they were due…as it’s not really a serious impact im OK with that. will pick it up again in due course I guess.
I was anticipating this too. Gives me some more time to play with things like shielded power cables and filtered power distribution and isolation transformers
Perhaps I have the most interesting grounds for trying lots of things like shielded power cables, isolation transformers and filtered power distribution boards etc…oh lets not forget FMC’s which I do have in play and shielded LAN cables.
