Windows 10 PC (Core i7 4790K, 32GB Ram, 2TB SSD), On Wifi (line of sight to router). Fully updated OS. Roon 1.7 Build 555.
Music: Local library (9000 tracks) stored on same PC as Core. + Tidal
Remote: iPhone 11Pro (OS and Roon app updated).
Synology RT2600ac Router
Bluesound Flex 2i (Ethernet wired directly to router)
Bluesound Soundbar 2i (Ethernet wired via TP Link ethernet power line adapter)
Over the past few days I started having problems with internet radio. More specifically, some stations that used to work, now fail to start. If I hit play I get the following message:
Playback was interrupted because a track failed to load.
This affects some radio stations but not others. The have all been added a long time ago (Tunein links) and used to work just fine. Example:
This station plays fine when I access it via Tunein directly on my PC (where core is running). If I add this to Roon, it fails to start.
Any help will be greatly appreciated
Many thanks
Yiannis
