Issue with Live Radio
Ubuntu 20.04.1 LTS/Core i7 16Gb//1.7 Build 610
Core Ethernet, End Points Mix Wireless and Ehternet
Raspberry Pi/Hifiberry DAC and Raspberry Pi audio out
No Live Radio station will play - get the “Playback interrupted because a track failed to load” message… this happens for ALL Live Radio stations and ALL endpoints!
See this in the logs when I attempted to play a couple of stations:
10/19 06:36:14 Debug: [easyhttp] [34] GET to https://internetradio.roonlabs.net/2/api/stations/7b5e75fe-96d2-4392-af64-23d39b0c0d74?format=msgpack returned after 175 ms, status code: 304
10/19 06:36:14 Info: [stats] 3763mb Virtual, 602mb Physical, 121mb Managed, 0 Handles, 72 Threads
10/19 06:36:16 Debug: [easyhttp] [35] GET to https://internetradio.roonlabs.net/2/api/stations/7b5e75fe-96d2-4392-af64-23d39b0c0d74?format=msgpack returned after 52 ms, status code: 304
10/19 06:36:16 Trace: [zone voluRest] Playing Channel
10/19 06:36:16 Trace: [zone voluRest] Selecting Source state=Paused
10/19 06:36:16 Info: [library] saved recent ProfileId=01ea6dc8-519b-4ce3-ab63-b7dbb9db13ce Time=10/19/2020 10:36:16 AM DataType=channel Type=play MetadataId=802 ContentId= LibraryId=802
10/19 06:36:16 Info: [zone voluRest] Canceling Pending Sleep
10/19 06:36:16 Trace: [voluRest] [Inactive] [LOADING @ 0:00] WPTF
10/19 06:36:16 Trace: [musicpowerstate] music is playing, preventing idle sleep
10/19 06:36:16 Trace: [internetradio] Channel Player: Fetching URL [https://16813.live.streamtheworld.com/WPTFAMAAC.aac]
10/19 06:36:17 Trace: Attempting to play channel URL: icy://16813.live.streamtheworld.com/WPTFAMAAC.aac
10/19 06:36:17 Info: [voluRest] [zoneplayer] Playing: channel://icy%3a%2f%2f16813.live.streamtheworld.com%2fWPTFAMAAC.aac
10/19 06:36:17 Warn: [zoneplayer] I/O Failure While Opening Sound: icy://16813.live.streamtheworld.com/WPTFAMAAC.aac: Read failure: ExternalProcMissing
10/19 06:36:17 Info: [voluRest] [zoneplayer]     Open Result (Playing):Result[Status=IOError]
10/19 06:36:17 Warn: [zoneplayer] couldn't play URL channel://icy%3a%2f%2f16813.live.streamtheworld.com%2fWPTFAMAAC.aac: other error
10/19 06:36:17 Warn: [zone voluRest] Track Stopped Due to Error
10/19 06:36:17 Info: [zone voluRest] OnPlayFeedback StoppedEndOfMediaUnnatural
10/19 06:36:17 Info: [zone voluRest] Canceling Pending Sleep
10/19 06:36:17 Trace: [voluRest] [Inactive] [STOPPED @ 0:00] WPTF
10/19 06:36:17 Debug: [easyhttp] [36] GET to https://internetradio.roonlabs.net/2/api/location?format=msgpack returned after 49 ms, status code: 304
10/19 06:36:17 Error: could not write key: internetradio_location =  -- Object reference not set to an instance of an object
10/19 06:36:17 Trace: [radio/library] got location
10/19 06:36:17 Debug: [easyhttp] [38] POST to https://internetradio.roonlabs.net/2/api/reporting/internetradioplayback/events?format=msgpack returned after 51 ms, status code: 400
10/19 06:36:17 Debug: [easyhttp] [39] GET to https://internetradio.roonlabs.net/2/api/location?format=msgpack returned after 47 ms, status code: 304
10/19 06:36:17 Debug: [easyhttp] [37] GET to https://internetradio.roonlabs.net/2/api/location?format=msgpack returned after 163 ms, status code: 304
10/19 06:36:17 Debug: [easyhttp] [40] POST to https://internetradio.roonlabs.net/2/api/reporting/internetradioplayback/plays?format=msgpack returned after 48 ms, status code: 400
10/19 06:36:17 Debug: [easyhttp] [41] POST to https://internetradio.roonlabs.net/2/api/reporting/internetradioplayback/events?format=msgpack returned after 48 ms, status code: 400
10/19 06:36:17 Debug: [easyhttp] [42] GET to https://internetradio.roonlabs.net/2/api/location?format=msgpack returned after 48 ms, status code: 304
10/19 06:36:17 Debug: [easyhttp] [43] POST to https://internetradio.roonlabs.net/2/api/reporting/internetradioplayback/plays?format=msgpack returned after 51 ms, status code: 400
10/19 06:36:27 Trace: [radio/query] performing channel query
10/19 06:36:27 Trace: [radio/query] query returned 7 Sooloos.Broker.Api.Channel(s)
10/19 06:36:27 Debug: [easyhttp] [44] GET to https://internetradio.roonlabs.net/2/api/stations/all?count=100&sortby=popular&location=auto&maxDistance=402&format=msgpack returned after 191 ms, status code: 200
10/19 06:36:27 Debug: [easyhttp] [50] GET to https://internetradio.roonlabs.net/2/api/languages/all?language=&count=20000&format=msgpack returned after 189 ms, status code: 304
10/19 06:36:27 Debug: [easyhttp] [46] GET to https://internetradio.roonlabs.net/2/api/languages/all?language=&count=20000&format=msgpack returned after 207 ms, status code: 304
10/19 06:36:27 Debug: [easyhttp] [45] GET to https://internetradio.roonlabs.net/2/api/stations/all?count=100&sortby=popular&location=auto&format=msgpack returned after 212 ms, status code: 200
10/19 06:36:27 Debug: [easyhttp] [51] GET to https://internetradio.roonlabs.net/2/api/categories/toplevel?count=20000&format=msgpack returned after 198 ms, status code: 304
10/19 06:36:27 Debug: [easyhttp] [47] GET to https://internetradio.roonlabs.net/2/api/categories/toplevel?count=20000&format=msgpack returned after 209 ms, status code: 304
10/19 06:36:27 Debug: [easyhttp] [49] GET to https://internetradio.roonlabs.net/2/api/stations/all?count=100&sortby=popular&location=auto&format=msgpack returned after 311 ms, status code: 200
10/19 06:36:27 Debug: [easyhttp] [48] GET to https://internetradio.roonlabs.net/2/api/stations/all?count=100&sortby=popular&location=auto&maxDistance=402&format=msgpack returned after 315 ms, status code: 200
10/19 06:36:29 Info: [stats] 3847mb Virtual, 621mb Physical, 137mb Managed, 0 Handles, 74 Threads
10/19 06:36:31 Debug: [easyhttp] [52] GET to https://internetradio.roonlabs.net/2/api/stations/fc5c46ed-f6f8-485e-b124-a23db1b83a91?format=msgpack returned after 41 ms, status code: 200
10/19 06:36:32 Debug: [easyhttp] [53] GET to https://internetradio.roonlabs.net/2/api/stations/fc5c46ed-f6f8-485e-b124-a23db1b83a91?format=msgpack returned after 43 ms, status code: 304
10/19 06:36:32 Trace: [zone voluRest] Playing Channel
10/19 06:36:32 Info: [library] saved recent ProfileId=01ea6dc8-519b-4ce3-ab63-b7dbb9db13ce Time=10/19/2020 10:36:32 AM DataType=channel Type=play MetadataId=1058 ContentId= LibraryId=
10/19 06:36:32 Trace: [zone voluRest] Selecting Source state=Stopped
10/19 06:36:32 Trace: [internetradio] Channel Player: Fetching URL [http://94.23.201.38:8010/;mp3]
10/19 06:36:32 Trace: [voluRest] [Inactive] [LOADING @ 0:00] Audiophile Classical
10/19 06:36:32 Trace: [musicpowerstate] music is playing, preventing idle sleep
10/19 06:36:33 Trace: Attempting to play channel URL: icy://94.23.201.38:8010/;mp3
10/19 06:36:33 Info: [voluRest] [zoneplayer] Playing: channel://icy%3a%2f%2f94.23.201.38%3a8010%2f%3bmp3
10/19 06:36:33 Warn: [zoneplayer] I/O Failure While Opening Sound: icy://94.23.201.38:8010/;mp3: Read failure: ExternalProcMissing
10/19 06:36:33 Info: [voluRest] [zoneplayer]     Open Result (Playing):Result[Status=IOError]
10/19 06:36:33 Warn: [zoneplayer] couldn't play URL channel://icy%3a%2f%2f94.23.201.38%3a8010%2f%3bmp3: other error
10/19 06:36:33 Warn: [zone voluRest] Track Stopped Due to Error
10/19 06:36:33 Info: [zone voluRest] OnPlayFeedback StoppedEndOfMediaUnnatural
10/19 06:36:33 Info: [zone voluRest] Canceling Pending Sleep
10/19 06:36:33 Trace: [voluRest] [Inactive] [STOPPED @ 0:00] Audiophile Classical
10/19 06:36:33 Debug: [easyhttp] [55] GET to https://internetradio.roonlabs.net/2/api/location?format=msgpack returned after 51 ms, status code: 304
10/19 06:36:33 Error: could not write key: internetradio_location =  -- Object reference not set to an instance of an object
10/19 06:36:33 Trace: [radio/library] got location
10/19 06:36:33 Debug: [easyhttp] [54] GET to https://internetradio.roonlabs.net/2/api/location?format=msgpack returned after 78 ms, status code: 304
10/19 06:36:33 Debug: [easyhttp] [56] POST to https://internetradio.roonlabs.net/2/api/reporting/internetradioplayback/events?format=msgpack returned after 69 ms, status code: 400
10/19 06:36:33 Debug: [easyhttp] [57] POST to https://internetradio.roonlabs.net/2/api/reporting/internetradioplayback/events?format=msgpack returned after 50 ms, status code: 400
10/19 06:36:33 Debug: [easyhttp] [58] GET to https://internetradio.roonlabs.net/2/api/location?format=msgpack returned after 53 ms, status code: 304
10/19 06:36:33 Debug: [easyhttp] [59] GET to https://internetradio.roonlabs.net/2/api/location?format=msgpack returned after 77 ms, status code: 304
10/19 06:36:33 Debug: [easyhttp] [61] POST to https://internetradio.roonlabs.net/2/api/reporting/internetradioplayback/plays?format=msgpack returned after 52 ms, status code: 400
10/19 06:36:33 Debug: [easyhttp] [60] POST to https://internetradio.roonlabs.net/2/api/reporting/internetradioplayback/plays?format=msgpack returned after 73 ms, status code: 400
What happens if you try a flac stream? For instance
TMEFolk Radio
Interesting! That station played just fine.
I did just update to Ubuntu 20.04, wonder if Roon is missing a dependency?
Here is the output from sudo systemctl status roonserver.service
oonserver.service - RoonServer
Loaded: loaded (/etc/systemd/system/roonserver.service; enabled; vendor preset: enabled)
Active: active (running) since Wed 2020-10-14 09:46:57 EDT; 5 days ago
Main PID: 193949 (start.sh)
Tasks: 116 (limit: 14297)
Memory: 1.8G
CGroup: /system.slice/roonserver.service
├─193949 /bin/bash /opt/RoonServer/start.sh
├─193958 /opt/RoonMono/bin/RoonServer --debug --gc=sgen --server RoonServer.exe
├─579027 /opt/RoonMono/bin/RoonAppliance --debug --gc=sgen --server RoonAppliance.exe -watchdogport=38693
├─579028 /opt/Server/processreaper 579027
└─579174 /opt/RoonMono/bin/RAATServer --debug --gc=sgen --server RAATServer.exe
Oct 19 05:02:20 redmenaceubuntu start.sh[193958]: Running
Oct 19 12:03:29 redmenaceubuntu start.sh[579027]: atom with <8 bytes is invalidSystem.Net.Sockets.SocketException (0x80004005): Connection reset by peer
Oct 19 12:03:29 redmenaceubuntu start.sh[579027]: at System.Net.Sockets.Socket.EndReceive (System.IAsyncResult asyncResult) [0x00012] in <69f8661c94644655a06862d3e6b439f6>:0
Oct 19 12:03:29 redmenaceubuntu start.sh[579027]: at Sooloos.RnetJsonClient+<>c__DisplayClass65_0.<_BeginRead>b__0 (System.IAsyncResult ar) [0x00046] in <51c894eb252e4920bfd1a29ff0dd38fc>:0
Oct 19 12:56:40 redmenaceubuntu start.sh[579027]: System.Net.Sockets.SocketException (0x80004005): Connection reset by peer
Oct 19 12:56:40 redmenaceubuntu start.sh[579027]: at System.Net.Sockets.Socket.EndReceive (System.IAsyncResult asyncResult) [0x00012] in <69f8661c94644655a06862d3e6b439f6>:0
Oct 19 12:56:40 redmenaceubuntu start.sh[579027]: at Sooloos.RnetJsonClient+<>c__DisplayClass65_0.<_BeginRead>b__0 (System.IAsyncResult ar) [0x00046] in <51c894eb252e4920bfd1a29ff0dd38fc>:0
Oct 19 12:59:14 redmenaceubuntu start.sh[579027]: System.Net.Sockets.SocketException (0x80004005): Connection reset by peer
Oct 19 12:59:14 redmenaceubuntu start.sh[579027]: at System.Net.Sockets.Socket.EndReceive (System.IAsyncResult asyncResult) [0x00012] in <69f8661c94644655a06862d3e6b439f6>:0
Oct 19 12:59:14 redmenaceubuntu start.sh[579027]: at Sooloos.RnetJsonClient+<>c__DisplayClass65_0.<_BeginRead>b__0 (System.IAsyncResult ar) [0x00046] in <51c894eb252e4920bfd1a29ff0
Just ran this command
sudo apt-get install ffmpeg
…and that fixed the issue…I guess the inplace upgrade from Ubuntu 18 to 20 did not upgrade that package.
Anyway, I’m back up and running with Live Radio!
Thank you!
Excellent.
