Issue with Roon/microRendu/Project Digital S2
Hi, I’m having issues with my set-up. Basically what happens if I select the microRendu the songs start up for a millisecond, but then jump to the next until the album has been gone through. No sound, it just jumps from one song to the next. It shows the song title and you see the playback info roundel change quickly, but then its on to the next song.
I had an issue with my hard disk connected to my Rock unit, which took me some time to understand, leading to re-installing Rock on the device. After that I had to reinstall ffmpeg, but that all seems to have gone OK and the system works well with the Lumin D2 and the NAD T758.
Below is some code taken from the microRendu which seems to indicate issues, but I don’t understand what. I have reinstalled the software, sequentially rebooted the network, but still the below:
[0000168] 28.849 TRACE alsa output setup: format is pcm 352800/32/2
[0000169] 28.850 TRACE opening [hw:0,0] 352800/32/2
[0000170] 28.850 TRACE prefer larger samples = 0
[0000171] 28.851 TRACE [ALSA] [hw:0,0] using hw pcmformat S32_LE bitspersample 32
[0000172] 28.851 TRACE [ALSA] [hw:0,0] Requesting 2 periods
[0000173] 28.851 TRACE [ALSA] [hw:0,0] Requesting 17640 frames/buffer (8820 frames/period)
[0000174] 28.851 TRACE [ALSA] [hw:0,0] Initialized with 2 periods with 8820 frames/period and 17640 frames/buffer
[0000175] 29.191 ERROR error in snd_pcm_hw_params: Input/output error (-5)
[0000176] 29.191 WARNING [lua@0x12a0ee4] [10.92.94.230:59220] setup failed: RAAT__OUTPUT_PLUGIN_STATUS_FORMAT_NOT_SUPPORTED
[0000177] 29.192 TRACE [lua@0x12a0ee4] [10.92.94.230:59220] SENT [9] {“message”:“RAAT__OUTPUT_PLUGIN_STATUS_FORMAT_NOT_SUPPORTED”,“status”:“UnexpectedError”}
[0000178] 29.366 TRACE [lua@0x12a0ee4] [10.92.94.230:59220] GOT [10] {“request”:“setup”,“format”:{“sample_type”:“pcm”,“sample_rate”:352800,“bits_per_sample”:32,“channels”:2,“sample_subtype”:“none”}}
The Roon diagnostic info identifies the Project perfectly.
Any advise where to look further?
Thanks, Rene
Go ahead and update the unit, wait for the Back to Main Menu link, and reboot the unit. Now go to Settings / RoonReady and press Save. Also, make sure the DAC is listed in Apps / DAC Diagnostics.
@Jesus_Rodriguez
Hi Jesus, thanks for helping out. I did the above.
Upgrade went OK, no issues (had upgraded earlier)
Did the DAC test, got the following:
DAC description: Pre Box S2 Digital 2772:0230
Diagnostic information for this DAC
Pro-Ject Pre Box S2 Digital at usb-ci_hdrc.1-1.1, high speed : USB Audio
Playback:
Status: Stop
Interface 1
Altset 1
Format: S32_LE
Channels: 2
Endpoint: 1 OUT (ASYNC)
Rates: 44100, 48000, 88200, 96000, 176400, 192000, 352800, 384000, 705600, 768000
Data packet interval: 125 us
Interface 1
Altset 2
Format: SPECIAL DSD_U32_BE
Channels: 2
Status: Unknown (status not available when device is not playing)
Simple mixer control 'Pre Box S2 Digital ',0
Capabilities: pvolume pswitch
Playback channels: Front Left - Front Right
Limits: Playback 0 - 127
Mono:
Front Left: Playback 127 [100%] [0.00dB] [on]
Front Right: Playback 127 [100%] [0.00dB] [on]
Simple mixer control 'Pre Box S2 Digital ',1
Capabilities: pvolume pvolume-joined pswitch pswitch-joined
Playback channels: Mono
Mono: Playback 127 [100%] [0.00dB] [on]
Simple mixer control ‘Pro-Ject Internal Clock Validity’,0
Capabilities: pswitch pswitch-joined
Mono: Playback [on]
I assume the above is correct.
I saved in Roon Ready and the system restarted/rebooted.
Went into Roon and selected default for the microRendu (which shows ‘USB output’ as connected, but shows the Pro-ject as the DAC.
Regretfully the same behaviour; a quick run through the songs on an album, but nothing plays.
Anything else I can try?
Cheers, Rene
Everything looks fine to me on our end. Your best bet is to get Roon support involved.
@Support
Jesus, thanks. Strange that the issue is only with the microRendu and not with the NAD or Lumin, but hopefully Roon support picks this up.
Cheers, Rene
Hi @Rene_Zwart,
Is there any difference in how the microRendu is connected compared to other endpoints?
Hi, thanks for the support. I have meantime been able to determine the issue is with the Pro-ject and not with Roon and/or the microRendu. Brgds, Rene
