Full form submission What’s happening? Something else
How can we help? I'm having trouble adding music to my library
Since updating my MacMini to Sonoma 14.3.1, Roon does not read my external drive which has all my digital files on it, the message I get is; ERROR LOADING FOLDER UNAUTHORIZED, any suggestions? Thank you, DEC
wizardofoz
(Mr Fix It aka The Wiz)
February 21, 2024, 12:50am
3
Check the access in macOS to external volumes for roon apps.
You didn’t say what macOS version you were on before, but I’m assuming something much older.
Thank you for responding, were do i find external volumes?
Yes, i was on the previous operating system.
wizardofoz
February 21, 2024, 2:07am
5
I’m not on my Mac so can’t screen shot it but iirc under system preferences and security.
Failing that search here for external disk macOS it’s been posted many times
Apple Macbook Pro mid-2015, 16GB Memory, 512GB local storage
Monterey 12.2.1
Music stored on two external hard drives (4GB each)
1Gbps/1Gbps fiber optic internet connection (AdTran wifi router)
Hardwired to router
Over 200K tracks
Roon is reporting that it can no longer access the folders on my external drives containing music. Roon will not let me navi…
System Settings > Privacy and Security > Files and Folders > Roon > Network Volumes
daniel
(Daniel)
February 26, 2024, 7:36pm
7
Hi @David_Coad1 ,
Thank you for your patience while we worked through the queue. Are you still having issues with using your external drive?
