Issue with simultaneous streaming from three streamers using Nucleus (ref#DX7054)
· Nucleus One
In "Connect to your Roon Server" page I have two icons looking as laptops, one of which is probably the real Nucleus, and the other is probably the MacBook ("MacOS...). It is possible, of course, not to connect to "Nucleus MacOS" if my MacBook is not to be used as a server any longer. This said, the real Nucleus is connected to the router via Ethernet, so please check if its configuration is correct. What comes to the three streamers, I got them all in the same Zone group yesterday. However, the "Group" function did not work for simultaneous streaming from all three streamers, although they all are now enabled in "Other network devices" (and the rest disabled). The major concern now is if this feature (simultaneous streaming from three streamers) will be reproduced in my system.
Hey @Arno_Hanninen,
Thanks for the report! We were able to review a fresh Nucleus diagnostic from your machine and found the following:
Grouping: The zone you’ve built uses the AirPlay versions of your three SOLOs, and Roon can only see one or two of them at a time. On the 15th, only Ruokasalin audio was reachable, so the group only played there. Your SOLOs are also Roon Ready, which is the better way to connect them. Please go to Settings > Audio, enable all three under the Roon Ready Audio section, and give them names. Then disable the AirPlay and Chromecast entries for the same speakers, including the old “Oleskelutila” entry (that speaker now appears as “Olohuone alakerta”). Once that’s done, the link icon will appear and you can group them. Roon doesn’t support grouping Chromecast devices, which is why the link icon was missing there.
Network: The SOLOs keep changing IP addresses, and Yläkerran audio hasn’t been seen by the Nucleus since October 10th. Please make sure all three are powered on with network standby enabled in the Argon app. If your router allows it, give each one a fixed (reserved) IP address.
Two servers: The second icon is most likely Roon running on your MacBook. Your Nucleus is the Roon Server, so on the MacBook just select the Nucleus, and the Mac then works as a remote. Your Nucleus also isn’t signed in to a Roon account at the moment (it was logged out on the evening of the 15th), so please sign it back in with the account that holds your subscription. Then, from your macOS taskbar, you can quit Roon Server running on the Mac.
Once those steps are done, let us know how the grouped zone behaves. If anything is still missing, please send fresh logs and we’ll take another look.
Hi Benjamin,
Many thanks for investigating the problem regarding grouping of my three Argon solo -streamers for multiroom listening. I am very happy if SOLOs can be grouped to Roon ready space. Indeed, now the two SOLOs downstairs are located in Roon ready space. Unfortunately, the SOLO upstairs is still stubbornly in Airplay, and the icon of this streamer does not provide the choice of grouping in the same group as the other two SOLOs. Here are two snapshots (sorry for the orientation, could not correct it) showing the problem. While writing this reply, SOLO upstairs changed its environment as Core Audio. What might cause it that instead of providing a possibility to choose it under Roon ready environment it does not provide this opportunity?
What comes to Nucleus, my MacBook provides three servers: Nucleus, “this Mac” and “Laptop” (the last referring to my windows-laptop, in which I downloaded Roon app last week). Now I have chosen the server “this PC” in my windows-laptop. For some reason, the PC provides Nucleus 2.64 and Nucleus 2.73 as equal alternatives to choose the server, but as they have not worked, I have so far chosen windows-laptop for the server. Are they equally valid, or does it matter which to use?
Now that I am writing this reply, it appears as if the three streamers can be grouped together. However, this is not true, because the third SOLO does not bear this name, but is called built-in-output.
Hope these comments give some ideas which would make it possible to help us make progress.
Hi @Arno_Hanninen,
Thanks for the update and the screenshots. Good to hear the two SOLOs downstairs are now set up as Roon Ready.
About the outputs called “built-in output” or “Core Audio”: those are the speakers of the computer you’re using Roon on (your laptop or MacBook), not the upstairs SOLO. Every computer running Roon shows its own outputs this way, so you can ignore them, or disable them in Settings > Audio if you don’t use them.
About the servers: your Nucleus should be the Roon Server for everything. To check, open Settings > General on the Windows laptop and on the MacBook. At the top, under “Roon Server”, it should show your Nucleus. If it shows the laptop or “This Mac” instead, click Disconnect and choose the Nucleus. If two Nucleus entries appear, pick the one showing version 2.73. If Roon Server is still running on the MacBook, you can quit it from the menu bar so it no longer appears as an option.
About the upstairs SOLO: the Nucleus hasn’t seen it on the network since October 10, which is why it only appears through AirPlay and can’t be grouped with the other two. Please check that it’s powered on, that network standby is turned on in the Argon app, and that it’s on the same network as the other two. Restarting it can also help. Once the Nucleus sees it, it will appear in Settings > Audio under Roon Ready. Enable it there and you’ll be able to group all three.
If it still doesn’t show up after that, let us know and we’ll take a fresh look at the Nucleus logs.
Hi Vadim,
Thank you for your comments and to-do suggestions, as well as for clarifying the odd names appearing in Settings. Good to know what the Speaker icons mean; however, they have been disabled all the time, so we can expect them not to have interfered with streaming.
Your comment re: Nucleus sounds worth trying. Once I’m back home again, I will run Roon simultaneously on Windows laptop and MacBook and see which version of Nucleus is running in MacBook, then choose 2.73 in MacBook and then quit it in the menu bar.
About the upstairs SOLO: I wonder why it has disappeared from the network, and why on October 10th. I changed the main router’s password on Oct 7th but I guess it should not have affect SOLOs or other devices using wi-fi? Upstairs SOLO has been on all the time, blinking green light (“no signal”). And no matter how many times I have disconnected and re-connected it.
What comes to having “network standby turned on” in Argon app? Is there an app (Argon app) that I can download to the Windows pc?
Arno
Hi again,
I did all that you suggested, both in MacBook and pc-laptop. After all the measures, I checked settings and opened Audio. Therein, I checked “Connected to Roon Server” page. On that page, there are two items: Nucleus HDMI A (Alsa) and Nucleus HDMI B (ALSA), but no SOLOs. Under “Other network devices” there are the two SOLOs which have been connected to Roon from time to time, now in two networks: “Via Airplay2” and “Via Chromecast streaming” and unfortunately, not under “Connected to Roon Server”. In addition, the SOLO located upstairs is not and has not been represented in any of the Audio -page options for all times mostly.
I activated the two SOLOs under Chromecast streaming and started to stream. The volume control was not working for several minutes, thereafter worked some minutes, then again not. The option to group them together for simultaneous streaming was also not there.
I cannot understand why my system produces this much trouble to all counterparts, and is constantly malfunctioning? My guess is that updates so frequent nowadays have made it impossible to configure the players and servers the way it worked so well until recently.
I strongly support your proposal to investigate the network compatibilities and find possible bugs or other barriers to make streaming possible again.
Back to your instructions regarding server choices. After choosing Nucleus as the server I switched off my MacBook, so I guess MacBook does not interfere in streaming now. However, I’d like to have the option to use either the pc-laptop or the MacBook as the server, which was always possible for MacBook using the SOLOs via Google home. I hope the Google home configuration still works in an other environment (summer house) so that I can switch the MacBook to work as a server when streaming in that environment.
Arno
Hi @Arno_Hanninen,
We’ve re-examined Nucleus logs to verify that there’s no Roon-side failure here. From what we can see in the diagnostics available, the cause of these network disruptions is external to Roon, most likely in the managed components of this mesh network that sit between the server and the Chromecast endpoints.
Here are our findings, along with our suggested next step.
The two downstairs SOLO units aren’t able to sustain TCP connections to RoonServer. AirPlay and Chromecast don’t rely on these sustained TCP connections to the extent RAAT/Roon Ready do, which is why those protocols are more reliable during actual playback.
RAAT, Chromecast, and AirPlay all rely on mDNS for device discovery traffic, which would include Group control. From what we can see in logs, the network isn’t forward mDNS traffic in the manner Roon expects. This is causing discovery issues with devices across protocols.
Lastly, network change events are frequently disrupting the entire ecosystem, including the connections between Roon Remotes, Roon Server, and the various endpoints involved. These began on October 7, when the router password changed. The upstairs SOLO in particular hasn’t reliably re-joined the network since.
Can you please elaborate on the make/model of the router you’re using in this setup, and whether you have any mesh nodes, access points, or managed switches? The log patterns we’ve observed usually involve one of those network elements. We can advise settings changes that will help optimize the network for Roon.
Please also set a fixed IP address for each of the SOLOs if you haven’t already. The upstairs SOLO might need to be power-cycled or factory reset to rejoin the network with the new WiFi password.
We’ll watch for your reply.
Hi,
Many thanks for examining my Nucleus logs and for other diagnostics. I inquired about the protocol and was told that my network protocol uses mDNS traffic. So this should be in order.
Indeed, the entire ecosystem is unstable and items keep on dropping off. The router in the system has been Asus AX1800 Dual Band (RT-AX53U; SmartWiFi 6 (802.11ax)) but due to the instability problem, I changed it back to the original router (Huawei OptiXstar K572 Edge ONT) provided by the internet provider. For all times, my system has included a 2nd mesh-router upstairs (a Huawei similar to the main router) connected to the main router via ethernet cable (and feeding Nucleus via ethernet cable).
To my slight surprise, once changing the main router to Huawei, the downstairs SOLOs soon organized themselves into group Chromecast and more, it was possible to run both these SOLOs simultaneously. Today, no longer so. However, they are still visible in "Other network devices (Chromecast). Also upstairs SOLO is now visible in this group. As discussed, the upstairs SOLO is not connected to internet all times, its led blinking all times. Perhaps that can be solved if given fixed IP address.
Tomorrow, I shall inquire the current internet provider to get fixed IP addresses. Hope it will stabilize the system. My question is, will it be enough to have three of them (for each SOLO), or should Nucleus also be included? Charges will incur. Another issue is how to program the SOLOs to get a fixed address? Any instructions welcome.
P.S. I am obliged to change the main router back to Asus, because only with that router, it is possible to control the property’s lights and house thermostats. Hope it does not matter any longer if SOLOs get fixed IP addresses.
… just another comment and question related to your comment (below): Does the network traffic have to be forward mDNS, and if so, does it depend on the service provider’s protocols? We got a new connection (optical fiber internet) in July and it works fine for all other purposes, but is it possible that the protocol in our home is not forward mDNS at present (see below)?
“RAAT, Chromecast, and AirPlay all rely on mDNS for device discovery traffic, which would include Group control. From what we can see in logs, the network isn’t forward mDNS traffic in the manner Roon expects. This is causing discovery issues with devices across protocols”.
Acquisition of fixed i.p. addresses is not an option, they are restricted to companies / enterprises and they cost 50 eur each (3 required) on monthly basis.
You misunderstand what @connor is suggesting - he is recommending that you assign fixed IP addresses to the SOLO devices in your home network, not asking your network provider to give you a fixed public IP address in the internet.
You should be able to set “reservations” in your router so that its DHCP server will always give the same IP address to a device in your home network - this is equivalent to having a fixed IP address.
Hi @Arno_Hanninen,
Thank you for the details. We had a fresh look at your devices, and there’s good news: all three SOLOs, including the upstairs one, are now on the same network as the Nucleus and visible to it as Roon Ready. What’s getting in the way now is that two Roon Servers are running at the same time: the Nucleus and your Windows laptop. A Roon Ready speaker can only be used by one Roon Server at a time, so the two keep taking the SOLOs from each other, and that’s why they come and go.
Please try these steps in order:
  1. On the Windows laptop, go to Settings > General, click Disconnect, and choose the Nucleus (the one at 192.168.1.8). On the MacBook, please do the same. Your Mac’s own Roon Server is also named “Nucleus”, which is why you see two of them, so please make sure you pick the one that is not the Mac. If Roon asks to move your authorization to the Nucleus, please accept.
  2. Update the Nucleus. It’s still on 2.73, while your apps are on 2.74: Updating Nucleus
  3. In Settings > Audio, please enable all three SOLOs under Roon Ready, give them names, and disable their AirPlay and Chromecast entries. Then use the link icon to group them.
About fixed IP addresses: as Geoff explained, there is nothing to buy from your provider. In your Asus router, please look for “DHCP reservation” (often under LAN > DHCP Server, “Manually Assigned IP”). Then add the three SOLOs and the Nucleus there, so they always get the same address at no cost. mDNS works inside your home network and doesn’t depend on your internet provider.
At the summer house you can still use the MacBook as Roon Server. At home, please keep only the Nucleus running as the server.
Please let us know how the group behaves after these steps.
Hi,
Both SOLO streamers located downstairs now got “reservation” in my router. Getting in to router’s settings, DHCP protocol is in use. Unfortunately, the upstairs SOLO did not appear in the router’s list and thus, it could be given a “reservation”. However, in Roon’s Audio Settings it is there together with the other two, in the group “chromecast” , and it has an ip address, also. Therefore, it is surprising that it does not connect to current wi-fi. What should I do? Take it to the vendor and ask if they can reset it to factory mode?
What comes to the upstairs mesh-router (Huawei, its model was reported in a previous mail), I am not sure if it is in Bridge or AP (?) mode. SOLO’s do not have an ethernet input, if this question was related to that possibility.
To my current disappointment, even if downstairs SOLO’s are both in the same group (Chromecast) now, there is no option displayed to group the two into simultaneous streaming. Should that work if the SOLO’s were in group “Roon”? I was advised to place the streamers under “Roon” (…Settings-Audio…) but I don’t think it is doable as long as the icons do not exist in group “roon”.
Getting back the possibility to stream simultaneously from two or three streamers is still what we must try to achieve.
Below is a snapshot of the situation now.
Hi @Arno_Hanninen,
Thank you for setting up the reservations. We had another look at fresh logs from your Nucleus, and I want to explain more clearly how grouping works in Roon, because it explains what you are seeing.
In Roon, you group zones from the zone list: select one of the zones, press Group, tick the other zones you want to include, and press Save. Roon can only group zones of the same type. Roon Ready devices can be grouped with other Roon Ready devices, and AirPlay devices with other AirPlay devices, but the two types cannot be mixed. Chromecast devices cannot be grouped inside Roon at all. That is why the Group option does not show your SOLOs together while they appear under Chromecast.
We also need to correct what we wrote last time: since October 9 your Nucleus has not been able to connect to any of the SOLOs as Roon Ready. The SOLO refused the connection, so the Nucleus currently sees them only through Chromecast. The upstairs SOLO has not appeared at all since then, most likely because it lost its Wi-Fi connection when the router password changed on October 7.
You have two ways to get all three playing together:
Option 1, works with Chromecast now. Create a speaker group with the SOLOs in the Google Home app. The group then appears in Roon > Settings > Audio as an extra Chromecast device. Enable it, and you can play to it like any other zone. More on this here:
Option 2, the best result in Roon. Connect the SOLOs as Roon Ready:
  1. Update the Nucleus, it is still on Roon 2.73:
    https://help.roonlabs.com/portal/en/kb/articles/updating-nucleus
  2. In the Argon app, please make sure all three SOLOs have the latest firmware and that Roon Ready and network standby are turned on.
  3. Restart the SOLOs and open Roon > Settings > Audio. They should appear in the Roon Ready section. Enable them, give them names, and disable their Chromecast and AirPlay entries.
  4. Group them as described above.
For either option, the upstairs SOLO first needs to rejoin your Wi-Fi. Please factory reset it and set it up again with the Argon app. Argon support can help with the reset if needed.
Your home network itself looks fine for this. The Nucleus, your laptop, your iPad and the SOLOs are all on the same network, so the upstairs Huawei is working as an access point as it should.
If the SOLOs still do not appear under Roon Ready after these steps, please let us know the time you checked and we will look at the Nucleus logs from that moment.
Hi Vadim,
Thanks a lot for your instructions in restoring the multiroom playback system. Your step-by-step instructions worked well; first in uploading the latest version of Nucleus, which I did for both pc-laptop and MacBook. After that, both of the downstairs SOLOs organized themselves to zone Roon Ready which was the 2nd and better choice. And it works now! Now it is possible to stream both SOLOs at the same time again, which is great. However, what comes to the SOLO upstairs, it seems that it cannot be reset to factory settings. I visited Argon Audio’s web pages and all there was of this topic, they instructed nothing more than “press reset for 5 seconds to boot the SOLO”. I have done it multiple times before, so that did not help at all. Perhaps I need to take it to the vendor and at worst, need to buy a new one. Disappointing, but necessary if you don’t come up with any other manouver.
Another small disappointment I faced yesterday: we were in our other home and I tried to run my SOLOs there using Roon. As I do not have Nucleus there, I always switch the server to MacBook and when required, I log in with my username and password. To my great disappointment, this time Roon humiliated me by asking if I’m new to Roon and ticking “if you already have an account”, the log-in page opened on top of Roon “dashboard”. After feeding my credentials, the page blocked me to return to the dashboard/listening interphase, so there was no listening available via Roon. As it has been possible to use Roon in another environment (in one environment at a time), I would like to ask if there’s anything I can do to fix the log-in problem - or Roon itself. Thanks.
Hi @Arno_Hanninen,
Great to hear the two downstairs SOLOs are back on Roon Ready and playing together. For the upstairs SOLO, Argon support is the best next step, since they can confirm whether the unit can still be reset or needs service.
About the sign-in problem on the MacBook: all the logs we’ve looked at so far come from your Nucleus, and they don’t record what happens when the MacBook is the Roon Server. To find out why the sign-in page won’t let you through, we need the logs from the MacBook itself, captured right after the problem happens. Next time you’re at your other home, could you please try this:
  1. Open Roon on the MacBook, choose the Mac as the Roon Server, and sign in the way you did last time.
  2. When the sign-in page gets stuck, write down the date and time. A photo or screenshot of the screen would help too.
Once we have the logs, we’ll go through them and let you know what we find.
Hi, Some very good news with the SOLOs! The two downstairs were fine already in the beginning of this week but the one upstairs which did not connect to our wi-fi at home was a problem. I took that streamer to the vendor, and they managed to get it connected in their wi-fi via AirPlay. When at home again, it came possible to see deviced in home wi-fi network, and after a few trials, the streamer appeared as a wi-fi item and after a moment, I was able to feed the username and passwd to it. Then it appeared in “Roon ready” zone together with the two other streamers and I was able to group them for multiroom playback.
What comes to the problem in signing-in on the MacBook in our 2nd home, I tried to change Nucleus to MacBook in our 1st home. It did not work any better here, so the problem should not be due to the wi-fi network in which MacBook is. This all happened less than an hour ago (21.12 - 21.13 EST). I try to send some photos in another reply shortly.
Here are some captures of MacBook’s screen this evening at 21.12 to 21.13 (EST). "Changing the server from Nucleus to MacBook (Thursday 5.11.2026 at 21.12 - 21.13 (EST time))
It is still impossible to change the server from Nucleus to MacBook (or other laptop), no matter if the laptop is in the wi-fi network of my home or the leisure home. I sent a stream of snapshots from MacBook’s display while trying to log in to Roon when MacBook was chosen as the server. I hope you go through the snapshots and find out what goes wrong in the system.
Hi @Arno_Hanninen,
Thanks for the photos and the exact time. They made it easy to find the moment in your MacBook’s logs.
The sign-in itself is working. The problem is which Roon account the MacBook ends up signed in to. Until October 12, the Roon Server on your MacBook used your usual account and was licensed without any trouble. On October 12, Roon asked you to sign in again, and since then the MacBook has been signed in to a different Roon account, one that has no subscription. So each time you pick the Mac as Roon Server, it asks for a license, is told this account has none, and shows “Start your subscription”. That’s the loop in your photos from November 5. It happens at both homes because it has nothing to do with the network.
To fix it:
  1. On the MacBook, open your web browser, go to the Roon account page (the “Arno’s Roon account” page from your photos) and sign out there. This stops the browser from signing you back in to the wrong account.
  2. Open Roon, choose the Mac as Roon Server, and sign in with the same email address your Nucleus uses. To check which one that is, connect to the Nucleus and look under Settings > Account.
  3. Roon will say your subscription is in use on the Nucleus and offer to move it. Accept. When you’re back home, choose the Nucleus again and do the same in reverse.
One subscription covers one active Roon Server at a time, so you’ll do this switch each time you move between homes.
Please let us know how it goes.
Hi Bejamin, thanks for the step-by-step instructions, they worked well. The key thing was that after the first steps, loggging in to my (one and the only) Roon account using MacBook was possible by opening web browser as you instructed. Canging between Nucleus and MacBook as the server is now quick and easy Thanks!
