Mac mini M1 8GB ram, Ventura 13.2
MacBook Pro 14 ghz Quad core intel i5 8GB ram
Wireless connection to Bluesound Node
My Mac mini had been working for a year until I upgraded from OS Monterey to Ventura.
After the upgrade, the Roon ‘Audio’ page is blank.
But when I change over to my MacBook Pro it works fine
Hi, fellow user here
So when you use your mini none of the audio endpoints do show, but when you use remote roon on you MBP you are seeing all your audio endpoints?
Do you see your mini speakers on the osx audio prefs?
Maybe reinstalling the roon on mini would help.
@Peter_Schieve, I am confused in your Roon Core list. What is your primary Roon Core, the M1 or MBPro, or another device? Do you have two Cores available to you?
Welcome to the community! We’re excited to have you here, but also apologize for it being an issue that prompted for your first post.
What you’re experiencing sounds very similar to a known issue currently tied to Ventura specifically. You can read more about it here, as well as a potential workaround in the meantime:
