Managing audio devices on remote
Suddenly my two iPads says " No audio device found " when I start them as remotes. On the core I have Primare Dac Wasapi as the device. And I can play music through the core just fine. When I then try to manage the devices onthe remote, the Primare Dac Wasapi is already chosen. When I click it all I can do is disable it.The roon remote won’t recognize Primare Dac Wasapi.
Hi @bigj ---- Thank you for the report and my apologies for the troubles here. In order to help evaluate this issue properly, may I kindly ask you for the following information:
  1. Can you please give a brief, but accurate description of your setup, as seen here.
  2. Has this issue always been present when using Roon or did it just start recently? If it is indeed the latter, can you think of anything that has changed in your setup? OS update(s)? New applications? Firmware/driver updates?
-Eric
