I was following this tread even thought mine was working (under an early developper status…long story). I restarted the Roon server and it now shows Roon Ready.
One problem, it used to take upsampling up to PCM 768Khz and DSD 256, it will now accept only PCM up to 384Khz and DSD 128 Only.
The Matrix Mini-I Pro 3 is now working as a Roon Endpoint! It sounds very great. The noise floor is significantly improved over using the Matrix as streamer/DAC over my old Auralic Aries Mini. I can move the Auralic Streamer to my secondary sound setup.
I will used for a couple of weeks and then provide a detailed review.
Under the latest firmware it looks like the the maximum streaming resolution is 384Khz/DSD128. But as a USB DAC I’m seeing 768Khz/DSD512.
So I’m guessing it’s probably a stability requirement for Roon endpoint approval.
I’ll head over to the Matrix Audio website forum and ask…
interesting find… I didn’t actually update my firmware and so I still have the ability to stream 768khz/DSD256 as Roon ready endpoint. Regardless, 384khz/DSD128 isn’t really an issue for me either since I don’t have any content as high as this that native res.
