Mesh Network: Eero Pro?
I don’t use the Eero Pro, but have been using Eero 6+ for a more than a month now. My core is wired to the main unit and my main endpoint is wired to a satellite. I haven’t had a skipped Roon track since, either on my wired endpoint or other wireless endpoints.
This is the best upgrade to my audio system in a while :slight_smile:
This is exactly what I had hoped my experience would be like! And it should be like this. If I didn’t think this sort of experience were possible, I’d just ditch Roon entirely. But, I want what you’ve got! :slight_smile:
There’s something I’m missing, but I don’t think it has anything to do with eero - it’s working as advertised for everything else. And again, when I took eero out of the system completely in favor of ethernet straight from Fios, the problem was identical to when it was connected via eero.
I’m having the same problem. I assumed it was the Eero. You’re saying you hard wired and the problem persisted? Did you find a solution?
did you remove the FiOS modem as well? it’s only necessary if you use FiOS TV. I don’t, so the the FiOS fiber goes directly to my Eero, which acts as the router. no modem necessary.
it’s rock solid.
Hi @David_Frantz – if you follow my thread here, nothing I tried had any effect on the issue, including hard-wiring and removing my eero network from the system entirely.
https://community.roonlabs.com/t/too-many-failures-stopping-playback/220358
What ended up solving my problem was not exactly clear to me, but it IS solved, and I was right that it had nothing to do with eero.
After all the troubleshooting, one of the reps took a look at my account and saw that it had “flagged” for some reason, but I don’t know why and they never specified. Once that flag had been removed, Roon worked flawlessly in every configuration. It had nothing to do with eero or any of the other complicated bridging suggestions that were offered. Since the only program that I have an issue with on my network was Roon, it makes sense to me that the problem was Roon-specific, and not caused by an improper network setup.
“I had a chance to discuss your issues with our development group today. They’ve changed a flag on your account that will take effect after a couple of restarts. It may seem odd but doing it twice is necessary. Please let me know how things are going after doing this.”
I hope this is helpful. Wish I had more specifics to offer.
