we have roon nucleus and moon 280d. Roon version can be seen in picture above. 280d already equip with mind 2.
The problem is with usb connection. when we play MQA files, it seem DAC cannot convert in the right sampling rate. It act like it is not MQA dac. We try on decode and renderer, decode only setting and it show 48kHz on moon display. Of course, the renderer only will give you 96kHz. But, it is not 192kHz as file is intended.
MOON’s MQA implementation only works using the network (MiND v2) input on the device. There is no other MQA support on any other input (including USB).
Why not use the network input instead of USB? It’s Roon Ready and supports all of the same formats as USB. Plus it gives you the benefit of tighter integration and using the DAC’s remote to operate the transport controls (play / pause, skip, etc).
