Ethernet cabled with Broadband Internet, Ubiquity USG and Switches
NAD M33 wired, Blusound Node wired, Pulse wireless
My M33 not playing the sampling rates 88 and 192kHz through Roon. I plays all other rates like 44, 48, and 96kHz. With the two rates it tells about Audio Data is loading slowly. It does not matter if its from NAS content or Qobuz. I have checked with other Server machine without success. The M33 is playing this rates through BluOS without problems. All other players on the same network are playing all files and rates without problems through Roon. It seems to be a specific problem with M33.
Just as a workaround I have testet it with sampling rate conversion from roon an it works fine.
So if I covert from 88 to 96kHz and 192 to 96kHz the Music is playing correctly.
Based on these tests I think its impossible to have a performance problem of the server or the network.
Well I wish I had some advice, I am not that savvy !. Mine is playing everything I have including 176, which you did not mention. Do you have the latest updates from 4/8 and 4/13 ? You might have to do a reset of the M33 or maybe you accidentally did something in ROON. I would hope ROON has a suggestion for you or somebody smarter than me. Good Luck. Let us know the fix.
I am so sorry it took us this long to reply - please, accept my sincere apology
I’m very sorry to hear about the trouble playing 88 and 192kHz through Roon…is this still happening? Is Roon updated to the latest build?
If you navigate to Settings → Audio and click on the gear icon next to your M33 and select Device Setup, is there a limit for the device? (You might need to click on Show Advanced on the pop-up window).
See my Post on the NAD M33 Forum about further investigations…
The main problem still is the Bug not playing 88kHz sampling rate with enabled Dirac. Seems to be a gneral bug because other members repartet it too! John from Support has noted that, we hope he has made some progress about it.
